Wondering if anyone knows about using engine mounts from a ford which are cheaper and installing them into a 928, someone had told me that they had a shop install them,they were cheaper, stronger, and looked the same as the originals. Wondering if anyone has done this and what vehicle these mounts would be from?thanks
I've heard that too. I think it's the mounts from a ford truck. A ranger or f-150. 80s or 90's type vintage.
Typr a google search. I came across a write up once but have since forgot the specifics. But it is the real deal.
1987 944S, needs crank work 2010 Mini Cooper base |
They are Anchor #2698 mounts. i did not use them. Used solid rubber mounts instead. That way I do not have to worry about losing the hydralic function.
69 911 2.3Ez 85 928S |
The Anchor mounts work fine. You have to have an 83+ to use them or change out the crossmember to use the newer style mounts on older cars. You'll also need the motor mount plates if doing this on an older car.
John V. 1990 928GT 1980 928 EuroS (GT2-S) |
NAPA #602-1686, or 612-1686 for a solid version of the same
86 Carrera Targa - Garnet Red Metallic 88 928 S4 - Gran Prix White |
Go to Rennlist, you'll find scads of info on 928's, and this topic in particular.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
