-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   928 dash failure (http://forums.pelicanparts.com/showthread.php?t=291403)
prutser 07-01-2006 11:05 PM
928 dash failure
My 1978 928 has a reocuuring dashboard failure. Sometimes when I start the engine all dashboard instruments fail including dahoard light. Is this related to the adjusting of the steering with dashboard pod? Is there a fix?
Tanks
Ad
DPW928 07-08-2006 08:04 PM
If the left or right side fails individually, the problem is normally a blown/corroded fuse. Since both sides of yours are failing, the problem is either a corroded ground wire under the dash, a crack in the printed circuit card (behind the gauges), or a bad/corroded connection at the multipin connector on the printed circuit card.
prutser 07-13-2006 10:00 PM
Hi Dennis,
Thank you for your respons. I think the ground wire is cousing the trouble. I've heard it is sort of a sliding ground because of the adjustable pod. The instruments mostly come back into live when I put the steering/pod in the upper position.
efhughes3 07-16-2006 10:52 AM
Most problems with pod lights & gauges seem to be related to grounding. If you've not found it already, Rennlist is the place for 928 fanatics. Pelican is stronger for 911's.
