Porsche Crest Does anyone know where i can get a 928 aftermarket spoiler wing?
Does anyone know where i can get a 928 aftermarket spoiler wing cheap?
Old 05-23-2008, 01:01 PM
Network Native
Danglerb's Avatar
Funny how one word changes everything.
Junkyard on the back of a Pontiac Grand AM? Something like that I think fits.
Old 05-23-2008, 01:08 PM
Im not just looking for any spoiler I want the porsche 928 factory style spoiler the s4 type, but a aftermarket one that cost less than the factory price.
Old 05-23-2008, 01:15 PM
MPDano's Avatar
I know there is one here in San Diego that sells Fiberglass S4 wings for under $300. I'm getting one as soon as I get my car running.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-23-2008, 07:47 PM
Heavy Metal Relocator
rhjames's Avatar
I have an OEM S4 wing for sale---
$300 good condition.
PM if interested.
--Russ
Old 05-31-2008, 11:50 PM
proud new daddy!
low miler's Avatar
How 'bout this one:
http://www.**********.com/ShowItem/2366%20Porsche%20928%20S4%20Rear%20Wing%20Tail%20S poiler.aspx
Todd
#1 928 enthusiast on the planet!
Old 06-01-2008, 09:03 AM
How difficult is it to remove the stock rear spoiler's 3 parts and install the S4 one? is rear window trim different??
Old 06-02-2008, 07:00 AM
rhjames's Avatar
the side pcs are bolted/screwed to tabs under the seal, with one screwed to the inside of the hatch channel. the furthest forward tab is sometimes glued on, or pop rivetted on. the rear (middle) tab is screwed and pop rivetted on. removal of these tabs will leave holes---you can imagine what has to be done to fix this.
the hatch piece is no big deal to remove. first remove the upholstery under the hatch, and you will see the nuts that hold the spoiler on.
the spoiler hatch trim is just one piece across the top of the window, the non-spoiler trim is several pieces to go completely around the hatch window.
installing the S4 wing is somewhat tricky, as there is not much room under the hatch lip to attach nuts onto the wing studs (after you drill the holes in the hatch). You could remove the studs from the wing, and use hex head bolts (screwed into the wing from underneath) to gain some clearance.....this is how I attached my S4 wing onto my original hatch.
purchasing an S4 hatch may be a better solution for you--they are out there at reasonable pricing.....some S4/GT/GTS owners are now going wingless, so ask around....you might be able to score one relatively cheap.
--Russ
Old 06-02-2008, 09:14 PM
