usfromflorida's Avatar
82 looking to buy!
I wanted to get a little knowlege on a 928 I will be getting this weekend:
It's an L-jet.
It's an '82 US motor with Euro cams and MSDS headers. Other than that the motor is stock
Old 07-28-2008, 05:01 PM
Network Native
Danglerb's Avatar
Can't find my Ouija board, what do you want us to guess about it?
US 82 is pre S, so small brakes and a 95mm bore 4.5L motor, Euro cams without Euro pistons makes me wonder about valve clearance, but I suspect the HP isn't changed much if any with the smaller US air path through the intake, heads and valves.
If you post a VIN one of the guys might be able to tell you what it was once like, given it sounds like its been tinkered with.
Old 07-29-2008, 12:41 AM
Heavy Metal Relocator
rhjames's Avatar
I wouldn't worry about valve clearances with the cam change, and yes, there's probably little increase in power due to the heads, intake and throttle body not being changed. headers will help if the rest of the exhaust system is opened up. X-pipe would also help.
I would be skeptical about the cam change though, unless I saw casting numbers or something to verify the change (other than, "yeah, it's got Euro stuff in it")
good luck--
--Russ
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 07-29-2008, 01:32 PM
RicerSchnitzzzle
N2O-SHARK's Avatar
Where in Florida are you. Lots of us in FLA. Perhaps someone could help with an informal PPI?
'81 Euro 'S' 928 5-Speed 5.0L Hybrid "Ricerschnitzzzle" Wish list: RollBar, New Helmet and driving lessons
Wishes Done: Body kit, seats, No cat, Headers, X, Afterburners, 3" exhaust, short shifter , 17" TT Rims, 250HP N2O, MSD ignition w/retard+rev limit, MSD billet distributor, Accel Coil. 5.0L block, ported heads, JE race springs + .503 "S+" cams
Old 07-29-2008, 02:32 PM
