MPDano's Avatar
Porsche Crest MPDano's 928 going to Smog this Week
Ok, a little update for you (3.16.2009). I just spoke to my mechanic after they installed the good used AAV. They did their adjustments and got it to:
CO: .50
HC: 100
According to him, this is acceptable levels but he is not smog certified and has no way to check NOx with his tester.
The bad news:
Recently before I brought it to them, maybe around a month ago. I would start the car cold and I would get a lot of white smoke. In my used car experience, that would be coolant. It did disappear once it got warmed up though. Hence, why I did the oil change just before bringing it to the Mechanic. Well, he diagnosed it as a bad head gasket but he also said it is a very little leak since it goes away quickly. He said that I could try some of that leak sealer of some sort to try and fix that without removing the heads. Of which I highly don't want to remove heads. I seriously don't want to remove that engine. Anyways, he did state that this wouldn't cause me to not pass smog. Ok, I feel better now. Anyways, anyone got any suggestions on which sealer works of which you have experience with?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 03-16-2009, 06:49 PM
Network Native
Danglerb's Avatar
No clue on the coolant glue.
Smog it, drive it, and have some fun.
Old 03-16-2009, 07:11 PM
tedward515's Avatar
Look on the bright side, with all of the white smoke your neighborhood should be mosquito free
I knew a mechanic who talked about using something that would seal up real small coolant leaks, but of course I can't remember.
On a more serious note good luck with the smog test. I can't even imagine how frustrating those things must be.
89 928 S4 5spd project
81 928 5 spd gone
84 928S 5 spd euro gone
71 911T gone
83 944 gone
Old 03-16-2009, 07:50 PM
devilinblack's Avatar
Mine was smoking from under the hood when I got it smogged. The rear cam seals leaked and burned on the exhaust. Smog guy pointed at it and gave me a look, I just shrugged and he went on with the test.
Stephen Powers
1978 US 5-Speed
New SoCal928.com Community Site
Old 03-16-2009, 07:55 PM
MPDano's Avatar
Did it pass?
Old 03-16-2009, 08:06 PM
Yup, sniffer test was fine. Guess smoke under the hood doesn't count. I wouldn't think that water in the exhaust would either, just make sure the car is completely warmed up before going and don't shut it off!
Stephen Powers
1978 US 5-Speed
Old 03-16-2009, 08:30 PM
Heavy Metal Relocator
rhjames's Avatar
let us know how it checks out.....
--Russ
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 03-16-2009, 08:39 PM
MPDano's Avatar
HI Russ,
Oh yeah, you guys will be the first to know. Good or Bad.
Old 03-16-2009, 08:42 PM
MPDano's Avatar
Ok, time to update this thread. Brought my car to get Pre-Smog Inspected this morning. Drove the heck out of it prior. Here are my results:
15mph
HC=128max measured 128 PASS
CO=.93max measured .05 PASS
NO=1097max measured 136 PASS
25mph
HC=101max measured 87 PASS
CO=.73max measured .07 PASS
NO=927max measured 133 PASS
All PASS Tailpipe, should be good to go, right?
Results=FAIL
Why? 1981 US Model has EFI NOT CSI, no O2 Sensor found. My car is a 1981 EUROPEAN
The Inspector has to go by the year posted on the label which is a US 1981. A Euro 1981 928 is CIS with NO O2 Sensor. I need to go to a Referee Station and explain to them that it has the same FI System as a 1979 and I need a BAR Label to Inspect to a 1979 Standard. Although this is f%^%$# up, I do know that my tailpipe emissions was right on the money. Why can't I get a blind smog tech? BAR Referees closed on weekends, will call on Monday. Man, this is nerve racking!
Old 03-28-2009, 09:52 AM
Xlot's Avatar
One of the guys on that other site who has 4 928's (all 89/90) has a RoW car that had no O2 sensor from factory
When it was federalised, the O2 sensor was added to the exhaust pipe, but wasn't actually doing anything as the federalisation shop didn't know to change coding plugs etc.
Can't you just add a cheap old dead O2 sensor and plumb some wires into an unused fuse holder in the back of the CEL?
Various manual S4's
Old 03-28-2009, 10:15 AM
MPDano's Avatar
I could but they saw it was also CIS. Can't fake that.
Old 03-28-2009, 10:18 AM
Network Native
Danglerb's Avatar
Leo, you don't have a BAR sticker?
Hate to say it, but you may be in for a bumpy ride. Was it registered previously in Calif?
The referee station will require full compliance, not just a tail pipe, but end to end full compliance which means 100% of a Calif EPA certified emssions system needs to be present.
Did the smog guy actually run a test and the test directed you to a referee station, or did he look at it and say you need to go to one, ie have you been tagged in the system?
Old 03-28-2009, 12:45 PM
Yeah, if you're not in the system I'd plumb in an O2 sensor and make the wire disappear in the harness and find a dumber shop. The place I went to didn't even know that it wasn't a 911 so there's no way in hell he'd know CIS from EFI from a freaking coffee can.
But yeah, having to go to a referee is not a good starting point. Good luck with it and keep us posted.
Stephen Powers
1978 US 5-Speed
Old 03-28-2009, 01:56 PM
Dean_Fuller's Avatar
"referee station"!!! Gees....What next?
Old 03-28-2009, 05:16 PM
MPDano's Avatar
NO, this was just a pre-test and he recommended me to go to a Referee Station to get a new Bar Decal to state 1979, so it will be tested under 1979 specs. Ie, nothing was sent to the DMV. Do you think this will be an issue?
Old 03-28-2009, 05:39 PM
MPDano's Avatar
This is what is on my drivers side door jamb. Yes, this is a California Registered Vehicle. Last Pass was 1998, hence the 2000 year decals on the Blue California Plates.
Old 03-28-2009, 09:30 PM
Network Native
Danglerb's Avatar
Sticker will look something like ...
Old 03-28-2009, 10:19 PM
Network Native
Danglerb's Avatar
My advice, proceed slowly, and make no irreversible steps.
Check the smog history and maybe give it a try at the last place that passed it.
Old 03-28-2009, 10:21 PM
Network Native
Danglerb's Avatar
I'm not sure what it means, but that test is already in the system, and last passed was some Tuneup Masters in 98.
LAKESIDE RADIATOR /
LAKESIDE PORSC 928 1981 03/28/2009 08:12 a.m. T
ONE STOP AUTO TECH /
SANTEE PORSC 928 1981 07/11/2003 09:37 a.m. F
SANTEE PORSC 928 1981 06/12/2002 09:46 a.m. F
ADVANCED AUTOMOTIVE /
SANTEE PORSC 928 1981 06/12/2002 08:34 a.m. A
TUNEUP MASTERS #411 /
SAN DIEGO PORSC 928 1981 01/15/1998 10:26 a.m. P
Old 03-28-2009, 10:29 PM
Network Native
Danglerb's Avatar
Also looks like the Cal DMV registered it as a grey market vehicle on
06/03/1986 CA Motor Vehicle Dept. GREY MARKET
US 83 zinc metallic 5 spd, aka the nice car.
Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD
Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years.
Old 03-28-2009, 10:32 PM
