hitman3
car overheating flex fan ?
hi i live in Israel and in the past week i get my car over heated i changed the thermostat to a 70 c of a Mercedes instead of the 80c original the flex fan turn nicly i think how can i check what part making my car hot how do i fill oil in the flex fan if u have pic that will be wonderful i have a 928 1979 model mi opened the flex fan clean the bimaetalic strip
Old 08-16-2009, 11:22 AM
Banned
m21sniper's Avatar
you have a clutch fan, not a flex fan.
Old 08-16-2009, 12:27 PM
Network Native
Danglerb's Avatar
Thermostats control how cool the motor "can" run, but do nothing for overheating.
Old 08-16-2009, 02:12 PM
Petie3rd
Mrmerlin's Avatar
To fix the fan clutch you need to remove it then carefully cut the silicone sealant thats under the Bi metallic strip, slide this to one side then it will release.
Once this is done then you will see a brass pin in the center of the fan clutch , it is held in place with a green rubber seal,remove this pin and with a magnifying glass check it for scratches if its scratched you may be able to polish it with some fine grit sandpaper hold the pin in a small piece of rubber tubing so it wont be damaged .
Then you will also need to get some new silicone fluid.
Try the Local Toyota dealer they sell a tube of silicone its about 2 oz.
Toyota Part number is 08816-03001.
Depending on how much freewheeling the fan does you may need 2 bottles of it, I used one bottle to refill my fan.
If the pin is damaged then you will have to get another one or just buy a new fan clutch. The pin is not available so you may have to find a used fan to get this part from or make one
Old 08-16-2009, 02:37 PM
You can find some pictures on how to do it here:
http://www.peachparts.com/shopforum/showthread.php?t=195595
Its not Porsche 928 fan but this part is exactly the same.
Porsche 928S 4.7L 1980 European redhead
Old 08-19-2009, 07:38 AM
hitman3
[QUOTE=Mrmerlin;4839275]To fix the fan clutch you need to remove it then carefully cut the silicone sealant thats under the Bi metallic strip, slide this to one side then it will release.
hi do you have a pictures of the green rubber seal as i opened my clutch and i did not see this seal thank you michael
Old 08-19-2009, 01:23 PM
hitman3
please send me a pictures of the green seal maybe i can make one as i did not see one in my fan
Old 08-19-2009, 01:27 PM
hitman3
Originally Posted by yoni_d View Post
you can find some pictures on how to do it here:
its not porsche 928 fan but this part is exactly the same.
תודה יוני אבל זה קצת שונה
Old 08-21-2009, 02:16 PM
