Recovering dismantler
neil30076's Avatar
Question Ignition switch replacement
The return spring in the ignition switch has given up, and the key does not return from the start to run position on its own. I see that the switch mechanical part and electrical part are available separately, and I'm assuming i only need the electrical part ( 964-613-012-00).
Anyone care to confirm for me, also, can this be replaced without pulling the instrument cluster?
TIA
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 09-30-2009, 08:37 AM
MPDano's Avatar
Isn't the electrical part just that round plug on the backside of the Switch. I would think the actual metal assembly would have the return spring inside. Not positive though. By the way, the Compressor you gave me works great. Thanks again Neil!
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 09-30-2009, 09:01 AM
rjm65's Avatar
The ignition lock (the part you put the key in) does not have any return spring built into it.
If you pull the lock out, when you insert the key in it, it will turn freely from the off position all the way through to what would be the start position.
Old 09-30-2009, 09:20 AM
neil30076's Avatar
Leo, I can't tell from the parts lists, so i am hoping someone has replaced this and will chime in. Good news on the compressor, i just need to get my system recharged now.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 09-30-2009, 09:24 AM
neil30076's Avatar
Thanks, that was the confrimation I was looking for. Now just need to order the part. Looks to be common to a lot of Porsche, maybe Pioneer on Miramar even has one!
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 09-30-2009, 09:26 AM
MPDano's Avatar
Or 928 Intl is next day to us in SD.
Old 09-30-2009, 09:29 AM
neil30076's Avatar
The last 3 parts i called 928intl on they did not have new or used ( which suprised me) , their stock seems to be very low on small parts, good on the big ($$) items.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 09-30-2009, 09:33 AM
MPDano's Avatar
Hmm, yes, weird as I did inquire on a part last week and they didn't have it. I know they did have a complete OB car there for parts, but that's a different story all together. Sorry, had to. I'll stop now
Old 09-30-2009, 09:37 AM
I stock the ignition switch for $62.07 and only sell the Porsche one.
To many problems reported with the after market ones.
www.************
Old 09-30-2009, 05:01 PM
neil30076's Avatar
Thanks Roger, got one here in SD, cost a little more, genuine , and no shipping costs.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 09-30-2009, 06:29 PM
neil30076's Avatar
deleted - posted before engaging brain!
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 10-01-2009, 12:46 PM
MPDano's Avatar
I remember when my eBay Ignition Switch broke apart. The symptoms were no return spring action. I ended up buying one from 928 intl and it had the Return Spring action back.
Is this the part you bought?
Old 10-01-2009, 01:40 PM
MPDano's Avatar
If it's not on that pictured switch, it must be on the harness part that plugs on the back of the pictured switch.
Old 10-01-2009, 01:44 PM
neil30076's Avatar
That's the part, and the spring is in it - ordered yesterday , here before noon from Pelican, can't beat that for service. Now just need to pull pod and replace - Saturday task, tomorrow is air show at Miramar!
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 10-01-2009, 01:57 PM
MPDano's Avatar
Good deal Neil, glad you got it sorted out. Yeah, certain stuff you MUST get OEM. I learned the hard way.
Old 10-01-2009, 02:24 PM
