-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   which AC mounting bracket for a Porkensioner (http://forums.pelicanparts.com/showthread.php?t=499752)
morriss 09-17-2009 06:46 PM
I'm wanting to put a Porkensioner on when I do the wp and tb change and I have been told that I need to know which AC mounting bracket I have. What makes the two different and which one do I need? Pics would be wonderful.
Mrmerlin 09-18-2009 05:28 AM
Ah are you talking about the AC compressor or the air pump??
the only differences in the Porkensioner mounting are for the air pump / air pump delete.
One mount has a bracket to fit the pump the other doesnt
porken 09-18-2009 08:54 AM
It's only the '78-'79 steel AC compressor bracket that is a problem. (You can fit it with some drilling/grinding.)
If your bracket is aluminum, then it will fit.
'78-'79 steel
http://members.rennlist.com/porken/PKsnr78-79AC.jpg
'80-up aluminum
http://members.rennlist.com/porken/PKsnrNoAirOldNew.jpg
morriss 09-20-2009 04:58 PM
Wow, from Porken himself! I just checked and it looks like I have the aluminum; put a magnet to it just to check and it did not stick. Guess I'm good to go. Thanks gentlemen.
