which AC mounting bracket for a Porkensioner
I'm wanting to put a Porkensioner on when I do the wp and tb change and I have been told that I need to know which AC mounting bracket I have. What makes the two different and which one do I need? Pics would be wonderful.
1982 928 S Euro 5 speed
Old 09-17-2009, 06:46 PM
Petie3rd
Mrmerlin's Avatar
Ah are you talking about the AC compressor or the air pump??
the only differences in the Porkensioner mounting are for the air pump / air pump delete.
One mount has a bracket to fit the pump the other doesnt
Old 09-18-2009, 05:28 AM
inventor
porken's Avatar
It's only the '78-'79 steel AC compressor bracket that is a problem. (You can fit it with some drilling/grinding.)
If your bracket is aluminum, then it will fit.
'78-'79 steel
'80-up aluminum
POWERED BY PORKEN
1986 928S3 AT grandprixweiß weinrot #1195
1988 928S4 MT polarsilberm sw/grau #1023
liftbars.com porken.com S300s.com
Old 09-18-2009, 08:54 AM
Wow, from Porken himself! I just checked and it looks like I have the aluminum; put a magnet to it just to check and it did not stick. Guess I'm good to go. Thanks gentlemen.
Old 09-20-2009, 04:58 PM
