Engine removal
Gents,
I hit a snag while removing the engine from my 81 928S. I you follow the repair manual, it says to remove the motor mounts and place the engine slowly on the crossmember. Thats all well and fine - if the steering rack has been dropped - which in turn is not part of the jobdescription.
Now, the rest of the job is done, but when it comes to pulling the engine, it turns out, that I canīt pull the engine forward enough to clear the clutch, and therefore end up lifting the entire car with the chirruped.......not good.
Have I missed a point in the instructions?
Tanks gents
K.C.
80 928 Euro
81 928s
both projects on going
Old 11-08-2009, 06:45 AM
MPDano's Avatar
I don't have a Manual but an Auto. There was always room front to back just none side to side. Did you remove all in front of the engine? Everything up to my A/C Condenser was removed. Got pics?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 11-08-2009, 07:28 AM
Yep, removed it all and never hit a snag. The problem (in my limited min anyway ) is, that the maintenance manual tells you to pull the engine forward slightly prior to pulling the engine. Thats all fine and dandy.....but in order to pull the engine forward, you have to pull the engine up and over the lower crossmember.
I will post pics when I download my camera. Thanks for the snappy reply
K.c.
Old 11-08-2009, 08:08 AM
Petie3rd
Mrmerlin's Avatar
to remove the engine you dont have to drop the steering rack/
You do have to remove the clutch from the flywheel it drops down as a package, short shaft, pressure plate and intermediate plate, throw out bearing/guide tube, release arm and clutch discs.
Dont forget to add the wire spacers around the 3 pins that come out the back of the PPlate before you loosen them, so you can remove the release arm.
Once the clutch is out then you remove the bell housing to engine bolts 4 of them 19mm.
Also remove the MM bolts that hold the block to the mount brackets 2X 17mm +2 X 13MM per side
With a floor jack under the front of the TT lift it a bit then lift the engine it should lift up then forward, once the engine is up begin to feed the wire harness out of the firewall
Old 11-08-2009, 08:52 AM
Roger that - I will give it a go later.
Guys - thanks.
I will let you know hoe the project comes along.
K.c.
Old 11-08-2009, 09:09 AM
american-kiwi's Avatar
yes you need to remove the clutch...and its a easy job...whole unit comes out in one piece...remove the lower bellhousing with the starter motor....the hardest part may be moving the inter' connecting shaft back...mine was a little rusted and gummed up....John
John .........
1978 Porsche 928 5sp LSD
1982 porsche 928 5sp LSD
Old 11-08-2009, 04:05 PM
Good news. Removing the clutch did the trick. Strange however that this is not part of the procedure according to the Porsche Workshop manual. Oh well - its out of the bay as you can see. Now its time for cleaning, renovating, boosting....
Thanks for your help guys
K.c.
Old 11-12-2009, 04:54 AM
MPDano's Avatar
Now the fun begins! Take your time and seal it up right. My engine was out of my car for a few months and I made certain to use Silicone Gaskets where I could and sealed it up with the Red High Temp RTV on top of the normal Gaskets. Not a drop of oil anywhere and I got at least 2K since I put the engine back in.
Old 11-12-2009, 06:39 AM
Petie3rd
Mrmerlin's Avatar
dont forget to drain the block each bank holds about 1.2 gallons so have a big bucket handy
Old 11-12-2009, 07:36 AM
