mitsy's Avatar
timing marks on 928s
hi could anyone tell me or show me where the timing marks are on the cams im just about to get the belt off but cant seem to see any definite marks thanks
1983 928s euro white
Old 02-05-2010, 11:48 AM
there should be a small notch in the back side of the cam sprocket. It should line up with the notch in the rear timing belt cover for each cam gear. it is possible that you need to rotat the crank an additional 360 degrees to see them, as the cams will only rotate 180. if there are no notches visible turn the crank 360 and check again as they are most likely at the bottom of the cam gears. Also if you have a Euro S or a 4 valve you should have the crank at the 45 degree mark when removing the belt so that if one of the cams spins on you it won't cause piston/valve contact. I'll see if I can find a pic and post it as a reference.
Old 02-05-2010, 02:45 PM
Here is a pic borrowed from a rennlist post. Hope the original poster doesn't mind.
Old 02-05-2010, 02:49 PM
mitsy's Avatar
its a 4.7 euro s 83 so should the cams be held while taking the belt off
I thought this applied to the 32 valves. Don't you line up the 16 valves at TDC before removing the belt?
1982 928 S Euro 5 speed
Old 02-05-2010, 07:42 PM
MPDano's Avatar
It makes it a lot easier to get the new timing belt on correct when you do it this way, but not necessary. We're non-interference.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 02-05-2010, 08:04 PM
mitsy's Avatar
non interference does that mean the valves and pistons dont hit each other if the belt snaps
Old 02-06-2010, 12:56 AM
harborman's Avatar
You might find this of some interest.
928 S4 Service - Timing Belt
Old 02-06-2010, 07:16 AM
mitsy's Avatar
very much appreciated all thank you
Old 02-06-2010, 09:45 AM
