1982 928 us
2 connections- where do thet go.......
i have a connection near airpump and connection front pass side cant remember if they were plugged into anything. What are they too?.
Tbelt and wp went great, coolant and oil filled and started right up. Thanks To Everybody!!!!!!!!!!!! ![]()
1982 928 us
ohh but dont know if they go to eachother either the silver female connector at quick try seems to be little big for the plastic male connector.
looks like 1st picture will plug into second picture for AC compressor clutch.
86.5 Porsche 928, 75 Porsche 914, 2.0, 2001 Boxster. |
They plug together for your AC compressor.
1982 928 us
Sweet thanks thanks
A/C Clutch Relay -
Hey lfausty, Now would be a good time to add a heavy duty (fog light type) relay to your air-conditioning clutch circuit. When you press the dash mounted A/C ON/OFF button there is actually a small relay inside the Temperature Control Unit that supplies 12 volt power to the A/C clutch. This small relay is a bit under sized and can be a real pain to replace if it fails. It is very simple to connect in the energizing coil of a larger relay to the power coming from the small relay and then tap off a good solid 12 volt source (battery jumper post located on the passenger fender splash shield) to energize the A/C clutch. The integrity and life of the original circuitry is improved considerably since the newly added relay now handles the A/C clutch coil current.
I had trouble with an intermittent A/C cooling issue for several weeks one summer before I determined it was a problem with the original factory circuitry and not a compressor issue. It was really hard to look cool and sophisticated when your windows didn't work and the A/C had shut down in 100 degree Texas temps. I got right busy sorting out the electrics pretty !#$@ quick..... especially with the wife going on with blaugh blaugh - yahda - yahda - "if you want me to ride in this thing" yahda - yahda .... ![]() Good Luck, Michael
1982 928 us
i havent been even remotely near ac and its workings though yet but something to take note of.
A/C Compressor Clutch Circuit -
lfausty's Garage - 1982 porsche, i havent been even remotely near ac and its workings though yet but something to take note of.
I thought the two mating connectors you were initially asking about had turned out to be the power wire to your A/C compressor ? The added relay I mentioned is just a simple method to eliminate a potential problem on some of the early 928's. Good Luck, Michael
