worn distributor cap and rotor?
take a look at these ..how would they rate on a scale of 1 to 10 for wear?
1985 944 |
In the middle of the Cap, there should be a spring loaded piece that touches the Rotor. Looks missing in the Pic. Replace both Cap and Rotor. I got a hella deal from Rock Auto. Around $30 shipped for both.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Come to think of it. This is probably your issues with it running right. I was looking at your other posts. This would for sure make it sputter and die.
I removed that spring and contact and put it in another old distributor cap. still problem persists..but i already ordered new cap and rotor. i wish i knew about the rock auto deal, i was happy finding cap and rotor shipped for twice that. STILL what would you rate the wear at? My whole sputtering problem began after installing new bosch plat +2. perhaps this was too much load for old distibutor caps and rotors? I cleaned all contacts even replacing some connectors, just cleaned injector connectors they were a little dirty inside. the engine does respond after sputtering thru 2200-2500 rpm and then accelerates well. ..but lift off the gas and sometimes itll die...the problem seems to always be in low rpm. so hard to tell between spark issues and fuel issues...
1985 944 |
Well, I didn't know you could remove that spring. I never removed that piece in any of my Caps, to include any other car than a 928. I would go back to the tried and true Copper Plugs too.
why do you like copper better?-J
1985 944 |
Less expensive and is known to work great in our engines.
For example: Bosch Copper 78-84 7506 / 999 170 062 90 Item :WR8DC Unit Price : $2.50
Petie3rd
WR7DC available at autozone for 1.99 each
Thats for the copper tips use them they work well with the Bosch ignition system Check the distributor for a loose shaft ( up and down play )
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
I'm with Dano on this, wait for the new cap and rotor. btw Dano would you also use those plugs in an 89
Names Brad, Canada, Fort McMurray. Car is a 1989 928 5L AT from Japan, 17" rims, 95,000 k vin#WPOZZZ92ZKS842476 |
I'm using Pulstars in my '82. Working great so far.
1982 Porsche 928, Auto, 4.5 http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945 |
NO substitute
Distributor Cap Rotor Fuel Filter 2 Front HOOD struts For, $75.53 shipped ground. You CANNOT beat that, period. Go Rock...
I will leave the answer to this for those that can answer it correctly. I am really unsure of the later cars.
Search on Google for the current code
NO substitute
Cool, coupon codes are always good.
![]() I am looking around now for a Fuel Pump and Plug Wire kit, they are costly so taking my time to find the best product/price for the bucks... Rock has good prices on these as well, just wanna check all resources before dropping that $$$. |
yes, as mentioned piece looks missing from cap.
also, it does not look like the spark is hitting the middle of the open surfaces in the cap - my memory is that I haven't seen it like that, almost like the rotor is too low or the cap is too high, which also supports the issue of the piece and spring coming out of the cap |
