weird water leak inside the car
Hi Guys
We had a lot of rain lately and when I got into the car, I have noticed that the entire passenger carpet is wet. The thing is that I looked more carefully and it seems that the water got into the car from behind the glove compartment ![]() or from the fan area since all that are is completely wet... Does anyone know where I should look in order to seal that leak? Thanks!
Porsche 928S 4.7L 1980 European redhead
Petie3rd
it is probably the blower box seal leaking this requires the blower box be removed and new 3M strip caulk applied there is also a small hole under the RF fender at the rear where water can come in , this is then dependent on how the car is parked.
First look up at the blower box see if the threads are rusted this is an indication of water leaks
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Damn it...when I was restoring my dash bored I tried to remove the blower box but I couldnt...I think that in my attempts I damaged the seal
![]() If I couldn't remove it on the first time, how am I going to do it now?
Petie3rd
First drop the CE panel after disconnecting the battery,
put a towel over the Ce panel. Disconnect the blue hose under the plastic cowl in the engine compartment just in front of the wiper motor. remove the nuts from the blower box, then remove the 2 blower motor mount screws from the top and the single bolt from the bottom then gently pry down, the blower Also i suggest to limit the use of wierd in your post headers as it will make looking for this in the future easier to find
Thanks for the 2 advices!
![]() I am sorry but can you please tell me what is the CE panel?
Check to see if the black plastic shield cover under the hood near the firewall is missing or cracked.
CE panel is located at the feet of the passenger. Just pull down the carpet and you'll see a wood panel that you can lift up. You CE panel consists of all your Fuses and Relays. I think CE stands for Central Electrical
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Kyle C
Question on the rusted blower threads; mine are rusty above the CE panel, I thought this was an indication of a leaking seal (it still may be) but I also notices some rusty threads under the driver side dash, similar style/location to the passenger side. As far as I know there is nothing on the driver side of the car that could leak and cause those threads to rust like the pass. side, so I am wondering how good an indication of a leak the rusted threads above CE panel are? Or are these rusted areas just a result of our cars being 25+ years old? Has anyone else noticed this?
1974 911 1978 928 5spd hillclimb special 1984 928S 5spd, 1986.5 928S auto 1983 944, 1984 944 track car 1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S |
