wills928's Avatar
I like it!!!!
While out tinkering this am I cleaned all grounds on my seats and now they adjust up and down, well that was sweet! Then while taking parts off my donor 82 I had a aaaha moment with taking out the distributor, I went to "lucille" that's what I call my 84, and started tinkering with the distributor and turned counter and clockwise a few times listening to idle and watching idle , well anyways I think I found a sweet spot because it has a new steady idle,no hesitation in the gas peddle and responds Waaaay better! I think I'm going to have the 82 motor pulled and checked for valves and belts and everything but have the heads milled and try to squeeze a few extra ponies!
Old 08-02-2010, 09:28 AM
928 Newbie
dcrasta's Avatar
Man this hit and miss style of tuning is better suited for a SBC or Ford, not a car as complex as the 928. I would use some proper tools for setting timing for example..
Old 08-02-2010, 09:33 AM
bwmac's Avatar
To make sure that you are not going to cause ping. here is what I would do.
Connect a vacuum gauge, advance timing as you did to the max vac, then retard the timing 1 and a half inches of mercury on your vac gauge. to check on the road, with the engine hot carefully listen as you do some full throttle starts. you should not here any pinging.
Names Brad, Canada, Fort McMurray.
Car is a 1989 928 5L AT from Japan, 17" rims, 95,000 k vin#WPOZZZ92ZKS842476
Old 08-02-2010, 10:19 AM
Kyle C
I have been considering messing with the ignition timing on my 84 too. Using a vacuum pump I activated the vacuum advance diaphragm on the distributor at idle. Idle speed/sound changed, no pinging. With a timing light I think I measured the difference between normal idle and advance @ idle to be ~10 degrees. Can I safely rotate my distributor so that it gives an extra 10 degrees (not including vacuum advance)?
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 08-02-2010, 04:07 PM
wills928's Avatar
I don't know , but I am having it tested Tuesday morn, but I do notice a " livelier" engine sound and response!
Old 08-02-2010, 04:39 PM
Maleficio's Avatar
I timed my engine by feel, then bought a timing light and discovered that I was dead on.
Old 08-02-2010, 04:54 PM
wills928's Avatar
So did I by hand and by an aaahhha moment when i pulled the old dist out of my donor car! I marked it in my car as referrence then tweaked it by hand , and notice when I hand checked the spot where I started and ended is maybe less than 1/4 inch or mm or degrees, I'm anxious to see If I'm on or way off
Old 08-02-2010, 05:07 PM
Maleficio's Avatar
I advanced mine a hair, and it's much more responsive.
Old 08-02-2010, 05:48 PM
wills928's Avatar
Same here!!!!! Like I said,,,, I like it
Old 08-03-2010, 04:51 AM
80 928
I've found that the euro setting if 28deg is pretty spot on. If you disconnect your vac advance and look at the harmonic balancer, it equates to just about 8deg btdc. Hmmmm...... Kinda like the old american muscle cars eh? I know, I know...it's not a dyamamic adjustment like the factory recommends, but, the end result nets pretty much the same. Depending on what grade of fuel, and what engine you're running, adj as necissary. What can I say, I have old trucks, and tractors also.
-K
Old 08-03-2010, 12:27 PM
wills928's Avatar
I'm kinda going at it with the same mindset as I did in tuning my race bikes! Take it to kill, spray it and pray!!!! Lol
Old 08-03-2010, 02:15 PM
