928Shane's Avatar
door panel rebuild
Started the door panel rebuild. I got the passenger side done and put in today, tommorrow i'll try fiberglassing this one and hopefully be able to save it
1978 928 5spd 17"cupII's
Old 08-02-2014, 05:26 PM
Kool
AirtekHVAC's Avatar
Can't wait to see! Good luck!
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 08-02-2014, 05:50 PM
Network Native
Danglerb's Avatar
Do you have a hole cut in the door metal for that speaker to fit?
Old 08-04-2014, 10:57 AM
77tony's Avatar
WYIT, add a door armrest reinforcement kit and a pair of speaker baffles.02 T
Old 08-04-2014, 12:16 PM
928Shane's Avatar
no hole cut in the door for the speaker. Tony, armrest reinforcements a good idea. the drivers side has a homemade one at this time, seems to work well, not reinstalling radio, so no speakers. I'll let the voices in my head keep me entertained!
Old 08-04-2014, 01:02 PM
Network Native
Danglerb's Avatar
Which model Alpine is the driver, from the picture it looks way too deep to fit a stock door.
Next time my door skins come off, I am going with a reinforcement kit, 928intl sells them I think.
My problem is that I want to do everything, make the door panel all it can be etc, so I keep putting off starting.
Old 08-05-2014, 10:12 AM
Kyle C
I just purchased a set of the armrest reinforcements from Jim Doerr at 928Classics. They work well but I found some modification/trimming of the armrest plastic was necessary to make them near perfect.
Overall I would recommend them.
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 08-05-2014, 06:45 PM
Tony, what's involved in fitting the lower speaker? ( in the lower carpeted area of the door panel)
Cut inner door metal?
any clearance issues with the glass etc?
Russ
'82 928,2002 4.3 lexus quad cam VVTI V8,5 spd Auto.(at the front)BorgWarner 3.08/1 LSD-at the back-Weisach retained,Transaxle gone.Borla exhaust,XSchops Cayenne big brakes front ,968 front brakes rear.Mk4Supra m/s & servo. Alloy rad,1380kgs(3036 lbs(53%F/47%R))
Old 08-06-2014, 12:23 AM
looks like a real project > mine where the same or worse (1980 )
so I bought a perfect pair with all the rugs in good condition from a salvage yard for $50 in Santa Rosa Ca.
Going to another Salvage Yard today here in Las Vegas who I have heard has some 928's we shall see . A small place just discovered
This place ( Hayward Ca ) always has a lot of 928 parts but they are costly
https://www.partsheaven.com/
23694 Bernhardt,
Hayward, CA 94545
800.767.7250
510.782.0354 | Fax: 510.782.0358
Old 08-06-2014, 08:16 AM
77tony's Avatar
Good one
Russ
1" risers can be had for cheap if speakers are to deep. After finding out above that Shane will not be running speakers, Will post more over on the Just Peachy thread instead of littering up Shane's thread T
Old 08-06-2014, 12:01 PM
Network Native
Danglerb's Avatar
Early cars don't have grilles and mount the speaker with the face on the rear of the panel, makes for a very tight fit.
Old 08-07-2014, 09:40 AM
928Shane's Avatar
finally back at it today! using fiberglass and mat for strengthing a couple areas,we'll see how it goes.
Old 08-16-2014, 12:19 PM
928Shane's Avatar
here is the passenger side installed
Old 08-16-2014, 12:20 PM
stepson's Avatar
Nice job!
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 08-16-2014, 09:07 PM
928Shane's Avatar
now to get the vinyl/carpet back on
Old 08-17-2014, 05:29 PM
77tony's Avatar
Shane, Do the gluing in 2 stages. Contact cement your material of choice to the front of the door card, then carefully trim off excess after it dries and be sure to leave a little extra material. Flip the door card over and do a dry run without glue to get a feel for the material before gluing down the excess. Looks like someone previously cut out the middle of where the stock speaker was to make room for a component tweeter. Same thing happened to my door but I will be installing a component tweeter there. While you have the fiberglass/resin handy, you might want to reinforce that area on the back so if someone does lean into it they will make that hole even bigger.02 T
Old 08-17-2014, 05:47 PM
