Jamey's Avatar
oil pressure sensor
I am planning on replacing the oil pressure sensor on my '84S today. The new sensor came with a small gasket. Should I supplement this with a gasket sealant such as RTV silicone or the like. Can anyone give any recommendations. TIA
Jamey
'84 928S
www.geocities.com/jamey928/index.html
Old 01-13-2002, 08:51 AM
Thumbs up
If it is an aluminum or copper washer type gasket(I haven't replaced mine yet, so I don't know), then you shouldn't need any sealant. These types of seals are designed to crush to match the sealing surfaces. They should be replaced every time the part is removed and reinstalled.
If it is a gasket material type seal, a light coating of fuel and oil resistant sealant(RTV black or equivalent) on each side of the gasket will work just fine. Too much sealant will just squish out and make a mess, or end up in your oil.
Old 01-15-2002, 03:20 PM
Senior Member
Hello
sneak around there:
http://members.rennlist.com/v1uhoh/index.htm
Old 01-19-2002, 05:20 AM
