-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   Engine pull. (http://forums.pelicanparts.com/showthread.php?t=585122)
tmpusfugit 01-14-2011 04:15 AM
I used a lift like the one pictured in this thread to pull my 928 engine(s) without difficulty. I used it in the most extended position from the front of the car. I used a chain between the 2 engine lift points. Before removing the motor mounts and removing the bolts from the bellhousing the hoist would actually lift the entire front of the car. I don't recommend that by the way, I suspect it is hard on everything, but it was an observation made using my lift on a scrap engine and a test of how robust the hoist really was...it passed.
And as others have suggested it is possible on my hoist to extend it another 6" and drill a new hole in the arm for the lock bolt. Certainly not OSHA approved..hence my lifiting test above....and I did use both the support legs....
Anthony10370 01-14-2011 07:11 PM
OK I got the fender off; yeah I just had to pull harder to break the sealant glue stuff. Happy to not find rust underneath considering the amount of leaves and other S* in there.
I've also removed pretty much everything I need to for the engine removal, I just have the motor mounts, four bolts in the "bell housing," and the drive shaft link.
Fender removed:
http://forums.pelicanparts.com/uploa...1295060744.jpg
Drive shaft/pressure plate:
http://forums.pelicanparts.com/uploa...1295060831.jpg
Anthony10370 01-18-2011 07:51 PM
OK, so I got the engine out yesterday and attached it to the stand today. Hoping to start disassembly today also.
http://forums.pelicanparts.com/uploa...1295409066.jpg
http://forums.pelicanparts.com/uploa...1295409093.jpg
