weird water leak inside the car
Hi Guys
We had a lot of rain lately and when I got into the car, I have noticed that the entire passenger carpet is wet.
The thing is that I looked more carefully and it seems that the water got into the car from behind the glove compartment
or from the fan area since all that are is completely wet...
Does anyone know where I should look in order to seal that leak?
Thanks!
Porsche 928S 4.7L 1980 European redhead
Old 01-17-2011, 06:19 AM
Petie3rd
Mrmerlin's Avatar
it is probably the blower box seal leaking this requires the blower box be removed and new 3M strip caulk applied there is also a small hole under the RF fender at the rear where water can come in , this is then dependent on how the car is parked.
First look up at the blower box see if the threads are rusted this is an indication of water leaks
Old 01-17-2011, 07:20 AM
Damn it...when I was restoring my dash bored I tried to remove the blower box but I couldnt...I think that in my attempts I damaged the seal
If I couldn't remove it on the first time, how am I going to do it now?
Old 01-17-2011, 08:16 AM
Petie3rd
Mrmerlin's Avatar
First drop the CE panel after disconnecting the battery,
put a towel over the Ce panel.
Disconnect the blue hose under the plastic cowl in the engine compartment just in front of the wiper motor.
remove the nuts from the blower box, then remove the 2 blower motor mount screws from the top and the single bolt from the bottom then gently pry down, the blower
Also i suggest to limit the use of wierd in your post headers as it will make looking for this in the future easier to find
Old 01-17-2011, 09:11 AM
Thanks for the 2 advices!
I am sorry but can you please tell me what is the CE panel?
Old 01-18-2011, 05:23 AM
Nio Nio is offline
Check to see if the black plastic shield cover under the hood near the firewall is missing or cracked.
Old 01-18-2011, 02:38 PM
MPDano's Avatar
CE panel is located at the feet of the passenger. Just pull down the carpet and you'll see a wood panel that you can lift up. You CE panel consists of all your Fuses and Relays. I think CE stands for Central Electrical
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 01-18-2011, 02:43 PM
Kyle C
Question on the rusted blower threads; mine are rusty above the CE panel, I thought this was an indication of a leaking seal (it still may be) but I also notices some rusty threads under the driver side dash, similar style/location to the passenger side. As far as I know there is nothing on the driver side of the car that could leak and cause those threads to rust like the pass. side, so I am wondering how good an indication of a leak the rusted threads above CE panel are? Or are these rusted areas just a result of our cars being 25+ years old? Has anyone else noticed this?
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 01-18-2011, 05:45 PM
