harborman's Avatar
Octane setting
In trouble shooting my starting problem now solved, I discovered a wire disconnected on the LH or EZH computer. The wire is green and has a matching connector. It was unplugged and is located right by the computer connectors. It appears its for lowering the octane requirement. I think it said it retards the spark 3 degrees.
Do you run it connected or not? Mine came with it disconnected and I have not tried to connect it yet without finding out more. I have been using 93 Oct gas.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 03-02-2011, 12:01 PM
European Shark
riber.bentsen's Avatar
Disconnected = high octane
Connected = Low grade fuel.
Stated by Landseer (asked same question)
Edit: Just looked at a chart showing fuel rating for different 928s, and according to that, your car should be running 95 octane, so maybe you should try and connect the green wires?
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 03-02-2011, 12:39 PM
harborman's Avatar
Mine has been disconnected.
Old 03-02-2011, 02:19 PM
inventor
porken's Avatar
95 EU/RON = 89 USA/AKI - this is likely the recommended octane for the ROW 32V, which had lower compression pistons.
Super (92 USA/AKI=98 EU/RON) is called for in the manual for USA versions, but I never had any trouble running Plus/89 with the stock chips.
The EZF 'octane loop' (green wires) shorts the Temp I/air temp sensor, making the EZF think the airbox is very hot. It retards 3° at higher loads/rpm.
The LH 'octane loop' (brown wires) is an input to the processor. It just changes the O2 sensor swing pattern slightly. (Doesn't go as far lean, IIRC.)
POWERED BY PORKEN
1986 928S3 AT grandprixweiß weinrot #1195
1988 928S4 MT polarsilberm sw/grau #1023
liftbars.com porken.com S300s.com
Old 03-02-2011, 04:00 PM
