left or right hand thread
I have a 1968 912 1.6 engine.
I am trying to remove the fan from the generator shaft. I can not loosen the nut perhaps because I am really tightening it by going lefty-loosey. The fan belt side is standard thread direction and is off. Not enough of the bolt or shaft threads show on the fan side to be sure which way he threads go. I have soaked it with penetrating oil and even heated it.
Which direction do the threads on the fan side of the generator shaft turn? Do I need a stronger man to put more torque lefty -loosey or are the threads reverse direction so I need to go the opposite direction to loosen the nut?
Thank you
Old 04-13-2011, 07:08 PM
Recovering dismantler
neil30076's Avatar
Repost over on the 912 board, this is the 928 group.
BTW, if the 912 is the same as a 914 - left to loosen, use a wrench on the bolt and an impact hammer :-)
Good luck.
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 04-13-2011, 07:11 PM
my error. sorry
Old 04-13-2011, 07:16 PM
neil30076's Avatar
No need to apologize, good luck with the engine work....
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 04-13-2011, 07:19 PM
1982 928 us
10-31-2002 (post) generator removal - type in search box - and as stated above at the 912 forum. *more posted while i was typing -- only first post was typed but good 2002 thread. Have fun.
Old 04-13-2011, 07:23 PM
