MPDano's Avatar
Question Alternator Hot vs Cold Question?
I was wondering why my Volt Meter in my "S" shows 13.5 when cold (first thing in the morning), then when I start the car cold but leaving from work when the outside temps are higher, I get a lower reading on Volt Gauge like below 12.
Keep in mind I never checked "actual" voltage at the post. It's just an interior observation from the Drivers Seat.
Does this sound like a grounding issue? Or a symptom of one? Or is it something else?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-13-2011, 11:32 AM
BIMMERMIKE's Avatar
I have the same sypmtons however everything checks out
1986.5 A/T Meteor Metallic 928
Old 05-13-2011, 12:12 PM
Pete R's Avatar
Mine is the same way too.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 05-13-2011, 12:26 PM
Recovering dismantler
neil30076's Avatar
Same here, Leo.
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 05-13-2011, 12:34 PM
MPDano's Avatar
Hmm, consensus seems unanimous. Is all this even after total ground cleaning?
Maybe I should run a temp wire to my External Volt Meter so I can monitor this.
Old 05-13-2011, 12:58 PM
Maleficio's Avatar
I installed a voltage stabilizer, and it works very well, no more crazy voltage fluctuations, but the average voltage will fall some after the engine is good and warm, even though the hotpost always reads 13.5 volts no matter what.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 05-13-2011, 01:18 PM
SharkHead
JhwShark's Avatar
The only thing I can think of is that the three Red wires from the Post to the CEP may be corroded a bit. Check the terminations at the CEP and see if the wires are hardened. You could drop some energy along the way if the wires are degraded.
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 05-13-2011, 02:10 PM
Pete R's Avatar
my grounds are good, my contacts are clean, I have the proper alt shroud, I even have a mint alt intake hose properly routed to the inside fender well. I just seems to work that way. MP, is it causing an issue in the car, or just your head (stuff like that drives me nuts too)
Neon SRT4 track car
Old 05-13-2011, 08:29 PM
MPDano's Avatar
Honestly, right now it's in my head as I am a Gauge watcher. Been that way since I was a Teenager with a Triumph TR7 that always overheated. Just a habit I can't seem to break. I'm going to run a couple wires to the Hot Post and Ground connected a Multi-meter inside my car so I am not digging around under my hood at work.
I appreciate all the input guys. Maybe now I can relax and enjoy my weekend.
Old 05-13-2011, 08:46 PM
