jdill
fuel lines
hey guys, the steel fuel lines that run under my 79 car are in need of replacing, rusted soon to be leaking has anyone changed these lines with regular stock? any advice? thanx
79 928 euro -lint green/black leather 5 speed
Old 07-21-2011, 03:18 PM
harborman's Avatar
I would have to say that stock ones may not be available, but did you check all the sources?? If not you can make your own.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 07-21-2011, 04:42 PM
Make your own fuel line get a roll of the right size line from a summit or youe local speed shop and get some metric to an fittings.
The beast 1984 928s twin turbo 5speed LSD/ 508.6RWHP 495RW ft lbs 12.5 psig manifold pressure, MS2 and EDIS-8 nikasil block JE 2618 pistons (TripleT). 2001 AUDI A6 4.2 chip 320 hp. 2002 CHEV Tahoe 4wd. 1971 sonett race car GT4 National Champion now GTL class car sold. The words of a Ford GT man. ( Damit i need to get some turbos)
Old 07-22-2011, 04:12 PM
jdill
yeah ,that was my thought ,, looks like 3-8th steel line but wasnt sure what to do for the fittings,and if the roll of tubing is strong enough or should i use the steel line straights and bend em up,the vent lines in the back over the wheel are rotted too, back there i can see using the ez bend line but wasnt sure about under the car,i got the rubber lines and clamps from roger, so its time to make it all new,another chapter in rereshing the fuel delivery plumbing and ventilation
Old 07-22-2011, 06:34 PM
Just replace it from point A to point B and be done with it.
Old 07-23-2011, 03:25 PM
It is metric line so you need to get metric to AN. I believe it would be - 6 line which will fit in where the line runs under the car. Be there done that.
Old 07-23-2011, 04:21 PM
Pete R's Avatar
The rubber line going to on the return to my tank is bad, which goes to a factory hard line. I am going to cut an splice steel braided an8 (?) I'm using a compression fitting with a screw on connector on the other side. Lindsey racing makes a kit for the 944turbo and I'm basically adapting that. waiting for parts now.. Ill post how it goes.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 07-23-2011, 04:49 PM
jdill
yeah, im gonna drop the tank and replace everything,, all steel lines are corroded, i didnt know about line size or what an meant,,local mechanic told me there was no metric size lines,,only 3/8 or 5/16 i didnt think he was right,, i will pursue my search for the metric hard lines, and figure out how to make the fittings,thanx for all your help, btw pete i still have that engine in my shop, let me know if your interested,,peace
Old 07-24-2011, 05:42 AM
Make sure you get thee right fittings or you will be having a big leaky mess.
Old 07-24-2011, 01:32 PM
jdill
so mark, if youve already done this do you know what fittings i should get? the hard line attaches to the rubber lines ,so i will need a fitting to fit those lines, and my next question is where do you get the metric 6 tubing ?
Old 07-24-2011, 05:26 PM
jdill
okay i found the tubing in 6mm or 10 mm 10 is closest to 3/8 if i converted it right,,, fed hill they have fittings too for brake lines i wonder if they are the same?
Old 07-24-2011, 05:49 PM
RJ Performance here in Sarasota. I rerplace my rubber lines with Breaded lines .
Old 07-25-2011, 04:11 AM
