Unhappy Interference engines
Just spoke with a very good mechanic that does work on 928's and he said that 2v cars are no different than 4v ones. If going 50mph and the belt breaks there would still be valve damage. He said to keep the 911 and discourage the 928.
Old 11-09-2011, 12:31 PM
928 Newbie
dcrasta's Avatar
He is wrong.
Very different cars, From the toothed belts they use, to the tension on the belt, to the consequences of breaking belts. Tell him to stick to 911's and find someone else. You're in MD and there are a lot of good 928 people in MD.
Ditch the zero (bigoted against 928s)
Old 11-09-2011, 12:35 PM
MPDano's Avatar
There are some late 16v Euro Engines that may crash valves, but for the most part that answer would come from the 911 mechanics who dislike us
I have a 1981 and a 1983 16V and both are NON-interference Motors.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 11-09-2011, 12:38 PM
MPDano's Avatar
Also, if you do get a 928, run from that mechanic that gave such advice. We're all you need.
Old 11-09-2011, 12:40 PM
He does work on many 928's and has a great reputation so.......
Old 11-09-2011, 12:44 PM
What shops do work on 928's in Maryland?
Old 11-09-2011, 12:45 PM
MPDano's Avatar
Umm, then maybe we all need to know where this 928 mechanic is located so we can...
Old 11-09-2011, 12:47 PM
928 Newbie
dcrasta's Avatar
GWL123 >
~Other people may trust him to work on their cars, but someone that says '2v cars are no different than 4v ones' has demonstrated a very fundamental lack of experience and understanding with 928s.
He may be a decent general mechanic, and even a great 911 mechanic, but he doesn't know 928s'
Old 11-09-2011, 01:14 PM
Recovering dismantler
neil30076's Avatar
I have had the belt 'go' on my 81 twice since i bought it from new - and no damage. He is wrong. To get valve damage the piston needs to collide with the valves, and it ain't going to happen on the 16v non interference engines.
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 11-09-2011, 01:17 PM
Great I'll limit my choices to an '83/84. Reading thru the board and other sites there seems to be a lot to look at with the issues. The water pump and electricals are my main concerns. Is there a thorough checklist written to address?
Old 11-09-2011, 03:38 PM
928: Serial Enabler
You were right earlier.
Keep the 911.
Unless you like DIY with a high puzzle component.
( and based on this post you made, that is unlikely: Can anyone recommend an honest garage in Wash. D.C.? I need a minor tune-up for my '76 911.)
Obviously whatever mechanic you settled upon isn't 928-worthy.
The only ones that are have extensive and repetitive 928 knowledge.
Also, to make a selection based on interference vs non-interference is odd.
Both versions of the vehicle get the same maintenance.
Neither should EVER suffer from a belt mishap.
Unless you are intending to buy and not maintain.
If that's true, no 928 needs you.
84,85,86 928 cars
Old 11-09-2011, 03:45 PM
MPDano's Avatar
Try this thread as there are a lot of issues that have been addressed and fixed there. 83 and 84 are great years See above wavy dude in my Signature.
http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes.html
Old 11-09-2011, 06:35 PM
Network Native
Danglerb's Avatar
Mechanics that don't really know the 928 can be very expensive in the long run.
I stopped in a shop once that had some parts listed on Craigslist, and the owner was working on a 928 and and real proud of it. He just replaced a windshield for like $2,000 and was telling me how it was only available from the dealer. I told him a dozen of us locally just had genuine Sigla glass put in for $300 installed. His ignorance cost his customer $1700 and I am pretty sure that was the tip of the iceberg.
Old 11-09-2011, 08:15 PM
Engineer of profanity
924CarreraGTP's Avatar
Your mechanic needs to do a little research on the cost of repairing a 911 engine when the trashy timing chain tensioners fail.
The 928 is a better vehicle by leaps and bounds. I know because I own both of them but guess which one I chose to build a street racer out of?
The U.S.16V 928s only interfere if they have had larger cam grinds or excessive amounts of carbon build up. The stock U.S. 16 valves shouldn't interfere otherwise. Run Barryman's B12 chemtool through your gasoline in small amounts to blow out the carbon, and keep your timing belt serviced (tensioned) and it won't be a problem.
Also, install tensioner stops on your 911 timing chain tensioners or kiss that 6 cylinder VW goodbye too. lol
I'm sick of people being down on the 928. The cars were assembled right beside the 911s by the same people. The only difference is prewar combustion technology in the 911 verses premium combustion technology in the 928.
Years ago a mechanic I now work with told me all the 928 engines interfere. I said then "I believe its just the 32 valves". He later agreed with me. I have a chance right now to buy a 32 valve 928S cheap, but I don't want it because it is an interference engine. After sweating long and hard over my 911 and many 944s, I think I'll stick to the '83, '84 928s.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 11-09-2011, 08:25 PM
I'm still interested in a 928S. I can do some DIY work except for the timing and waterpump. I will let the expert handle that since its one long belt that turns everything. As for the carbon build-up hmmm.....will Seafoam ($10) also work? I don't think my mechanic was dissing the 928. He was just warning me of more expensive maintenance. Parts are plentiful for now and cheap as I come across many for sale on craigslist. Just doing some homework first.......
Old 11-10-2011, 04:57 AM
harborman's Avatar
I don't think the "interference engine" is peculiar just to Porsche. Don't a number of new cars also have these engines?
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 11-10-2011, 05:18 AM
MPDano's Avatar
You can easily do this yourself. We've covered all this in this forum. Get the parts and tool and we'll guide you through it. You literally can do this in an afternoon. The only real time used will be all the cleaning.
Old 11-10-2011, 05:51 AM
Pete R's Avatar
I think just about every engine now is probably interference. All the manufacturers are trying to increase compression to get the gas mileage. I have an Escort we are making into a Lemons car and THATS interference.. not really a good way to pick a vehicle.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 11-10-2011, 08:04 AM
MPDano's Avatar
My Mitsubishi Eclipse Turbo "IS" Interference and makes doing a Timing Belt on a 928 a cake walk. The Mitsu also requires a Balancer Belt besides the Timing Belt PLUS the Oil Pump Gear MUST be be on time. Seriously, a 928 TB/WP Changeout is like putting a Rubberband on versus the Mitsu.
Old 11-10-2011, 08:45 AM
neil30076's Avatar
+928 ^^^
My daughters Xterra needed a timing belt - its interference as well, and it is a major dis-assemble vs. a 16v non interference 928.
A 32v 928 needs more care, but not that much more difficult.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 11-10-2011, 08:49 AM
