1982 928S
georges 928S's Avatar
jumper post wire coroded
Hi guys, trying to clean the jump post, i found the heavy brown wire corroded with green stuf , i peeled some of insulation to get to a clean spot , no luck. how do i go about cleaning this wire and were does it go. is why iam having a cold start problem. appriciat any response. Thanks Ed.
Old 01-02-2012, 01:45 PM
MPDano's Avatar
Pictures. Brown is ground FYI. I hope your talking about two different things as the Jump Post is a Hot Positive Post.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 01-02-2012, 02:10 PM
European Shark
riber.bentsen's Avatar
It goes brown with age and heat, mine is too. Further down it gets red again..
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 01-02-2012, 02:33 PM
1982 928S
Re jump post
Hey guys, iam talking about hot post wire next to 14 pinbox ,there are 2 of them
going to the post, red one and brown one and they connects to the hot post.
the brown is the one cordded , i striped some of it about 6 inches and its all green color. Ed.
Old 01-02-2012, 03:20 PM
MPDano's Avatar
Are you talking about this one that "looks" brown? Probably was Red like Riber says. Anyways, I can't remember if this is the one that travels down to the Starter. If so, I would just replace it with a similar gauge wire. Just run it next to the Harness.
Old 01-02-2012, 06:04 PM
1982 928S
Hi Leo, looking at your picture the red wire is on the right side of picture and the
one on left is brown and that one is got corrosion (green ) Ed.
Old 01-02-2012, 06:51 PM
MPDano's Avatar
I actually linked another posts pic. Can you trace where it goes? The "brown" wire. I know Neil knows.
Old 01-02-2012, 07:04 PM
Recovering dismantler
neil30076's Avatar
Sure, can help here , will be back on line tomorrow am and ready to assist....
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 01-02-2012, 08:08 PM
neil30076's Avatar
George, that wire is the main feed from the back of the alternator to the post. You can replace it completely with a new 4gauge ( IIRC) wire, but it must be a high temp wire as it runs over the hot engine block.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 01-03-2012, 08:49 AM
As Neil stated, that is the main lead to the alt. and it runs through the main wiring harness across the front of the motor. While you are there, you may want to pop the top off the 17 pin connector and take a look at their condition. If that heavy main wire is pretty bad, then I bet that the smaller main leads from the pins at the connector are worse or not too far behind.
If your harness is toast, I have a spare one from an '84 Euro S that I could sell.
Old 01-03-2012, 11:23 AM
1982 928S
RE: Jumper wire
Thanks Neil and DougM, Doug m, i will check what you stated on the thread
about the harness . is the harness in good shape, i will let you know when i
check further on. Thanks both of you. Ed.
Old 01-03-2012, 12:08 PM
neil30076's Avatar
Not sure a 84 euro harness will work - and the connector on a 82 is 14 pin, btw.
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 01-03-2012, 01:16 PM
Maleficio's Avatar
Here's how I dealt with my rotten wires in that area:
http://forums.pelicanparts.com/porsche-928-technical-forum/544852-found-another-rotten-wire-today-pics.html
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 01-03-2012, 03:36 PM
neil30076's Avatar
or you can remake the entire harness!
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 01-03-2012, 03:46 PM
Maleficio's Avatar
Cool.
Old 01-03-2012, 03:47 PM
European Shark
I was at my garage today, and snapped a few pictures of my 14-pin connector and jump post.. Don't know if you can use them, but here you go:
And, just for kicks, some pics of my teeny-tiny garage, where my car (and I sometimes) spend those long lonely winter nights... That's what you get for living in the city :/
Old 01-04-2012, 01:43 AM
1982 928S
jumper post update
i cleaned my brown wire which goes to the alternator from hot post about 8 inches
from hot post and that made a lot difference to my gage, before only showed about
between 10 and 11 on the gage, after cleaning it reads bettween 12 and almost 13. all i did was used battery head cleaner foam spray and washed it with water.
Ed.
Old 01-05-2012, 09:50 PM
MPDano's Avatar
Ed.
Interesting, but corrosion does damage to metal which is your wire. Why trust it, just run a new one from 14 Pin to your Alt. It's a relatively short run.
Old 01-06-2012, 05:40 AM
1982 928S
jump post
Hi Leo, the wire starts from hot post to alternator, i will do that once i move to my
new house with 3 garages and RV parking, now i live in a condo and have no
place to work on it, i still have to clean my 14 pin wires and my CE panel. by the way, the red wire on left side of hot post looking at the picture, where does it go or hooked to. Ed.
Old 01-06-2012, 07:53 AM
My spare for sale is actually a 14 pin. Not sure why I was thinking 17 pin? Here are pics.
Old 01-06-2012, 09:17 AM
