A.J.
tychain99's Avatar
trunk latch/ cargo area
SO my trunk was stuck shut for a long time, I lost the key, huge fiasco.tried getting in touch with a lock smith , he had a few screws loose so that was a lost cause.. I bought that parts 928 the other day and took the mechanism off the trunk. crawled into mine, figured out where everything lined up, drilled a small hole, slid a screw driver through the pilot hole and popped the latch. .. the donor latch had a key that fit it, so i sanded it down repainted it, and now I have a trunk that works. .. right before i lost the key, i took everything out of the trunk, taped off the wires and interior, sanded out the battery well, removed the gasket, primed it all, and sprayed it with black undercoating. I finally got it open, so I could finally post the pics!
1980 auto- cashmere beige
1984 auto- black on black
Old 12-30-2011, 04:05 PM
A.J.
tychain99's Avatar
carpet is STILL being upholstered for those that replied to that other thread I had, idk why it is taking him so long, but someday maybe he'll finish it.
Old 12-30-2011, 04:55 PM
MPDano's Avatar
Looking Good!!
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 12-30-2011, 05:01 PM
Network Native
Danglerb's Avatar
Nice job.
Old 12-31-2011, 01:47 AM
I have a similar problem. Locked and no key Is there a way to release the lock from inside without doing any damage? I have another lock barrel and key but would rather open ,remove barrel and change contents to fit ignition key.
Old 01-03-2012, 06:28 PM
There should be a pull knob by the seat on the cover of the emergency brake handle. Next to the fader switch. Pulling up the knob with a door open is supposed to open the hatch. Of course you need your electrical system working and good grounds, especially on the door switch. If your interior lights come on when you open the doors then the door ground should be good. Also, there is an identical pull knob on the passenger side. You may also need to adjust the arm on the motor to open the hatch and of course if the mechanism is worn it may not open. Good luck.
69 911 2.3Ez
85 928S
Old 01-03-2012, 06:59 PM
Network Native
Danglerb's Avatar
Power hatch release didn't start til 84 or 85.
Old 01-03-2012, 07:14 PM
Recovering dismantler
neil30076's Avatar
Originally Posted by tychain99 View Post
Is the car actually bambous beige and brown interior? Mine is, and i have never seen another in that combo.
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 01-03-2012, 07:41 PM
A.J.
tychain99's Avatar
no, it is cashmere beige. it is like a khaki color, there are more pics in my garage photos. yours looks a a little more yellow. i really like it though. I like the unique 928 colors that didnt stay in production long.
Old 01-05-2012, 01:54 PM
A.J.
tychain99's Avatar
i drilled a small hole, less than 1/4 inch. it was easy and it gets covered by the carpet. I can post a pic of the hole and where it is. I just lined up my new barrel piece, figured out where the hole had to be in order to pop the strike and push it back enough to disengage. 10 minute job.
Old 01-05-2012, 01:57 PM
A.J.
tychain99's Avatar
pic of car, you can see yours is a little lighter maybe more yellow, mine is more brown
Old 01-05-2012, 02:03 PM
Thanks for the info I will try that. Did not want to destroy the body or frame to open the hatch.
please send a pic to waynestrutt@295.ca
Old 01-06-2012, 05:08 PM
