jdill
84 automatic
hey guys,, i went to test drive an 84 today,, radiator was split open,,smog pump was seized and there was no belt on the fan,the car was all there, but i took it for a short ride and the transmission would slip upon acceleration,, let off and it would grab again,the car has been sitting a long time,,, brakes were gone and power steering was not present,,most of these problems dont scare me but the tranny does...is there a cure for this shifting condition? i made the owner an offer of 1k but he didnt give me an answer as of yet
79 928 euro -lint green/black leather 5 speed
Old 01-29-2012, 08:39 PM
davetr's Avatar
sounds like th trans is low on fluid
Old 01-30-2012, 04:22 AM
Petie3rd
Mrmerlin's Avatar
top up the fluid in the trans first done keep driving it that way as you may have fried the clutches
Old 01-30-2012, 05:42 AM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
fluid motion
Check level and condition of transmission fluid. You will need to put the car together a bit to evaluate it and of course running it in present shape presents all kinds of dangers. You would need to patch the radiator and check to see if the coolant system holds pressure just to begin. Please don't run it without a proper functioning cooling system.
You are facing a project car of epic proportions and so proceed with great care. Good luck
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 01-30-2012, 01:23 PM
Engineer of profanity
924CarreraGTP's Avatar
If the owner doesn't take the 1K he can go **** himself. That's a stack of work buddy. I agree on the fluid level and condition though. I've been there and done that too.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 01-30-2012, 07:19 PM
Recovering dismantler
neil30076's Avatar
I paid $1100 for a perfect running 84 euro here in CA with a minor electrical problem, that car is not worth $1k, $500 maybe.
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 01-30-2012, 08:32 PM
19psi's Avatar
If the radiator is "split open" as you say, it sounds like someone may have run straight water in the cooling system and it froze.
I'd be very worried about a cracked block or heads.
George in Indiana
928 Weissach #153
Cayenne S
Old 01-31-2012, 05:34 AM
jdill
well the owner accepted my offer of 1k,,,,tommorow i will have AAA tow it back to my shop and i will keep you informed,,,,,i just sold my 85 because i bought a new-well used 07 e350 4matic ,but i always need broken cars around me,,,, it keeps me out of trouble
Old 02-01-2012, 03:22 AM
MPDano's Avatar
We need pics. We need pics
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 02-01-2012, 05:36 AM
davetr's Avatar
i agree w th cooling system, hope nothing is cracked
Old 02-01-2012, 11:44 AM
whatudrivin's Avatar
im subbing in for this one..... =)
Old 02-01-2012, 11:52 AM
jdill
winter ride actually cheaper than a 928 investment
Old 02-01-2012, 02:02 PM
jdill
so,where does one start with the checking of the tranny fluid ,, i never had an automatic,and there is no handbook,,,,,it seems to be slipping more than my test drive,,,,the owner probably beat the crap out of it after i test drove it,, i only moved it a couple hundred feet off the ramp truck
Old 02-02-2012, 02:41 AM
MPDano's Avatar
Put your car up on jack stands, make sure it's level to the ground. I also throw an extra set of old rims under the car with me just in case. Your Tranny is in the rear and the filler is on the Pass side. The Reservoir will have a mark on the side of it for where the level needs to be, clean it off if you can't see it. Your car must be warm "and" running when you check this. If it is low which it sounds like it is, then use a pump of sorts to get the fluid in the reservoir. Not sure if it matters but I have my car in Neutral. Once you get it topped to the line, get in the car and cycle through the gears with your foot on the brake. Do this a few times and put it back in Neutral. Check level and fill more if needed. All of this is done with car running, except the getting it on Jack Stands part.
Old 02-02-2012, 05:09 AM
jdill
thanx dano,what fluid is correct for this automatic transmission
Old 02-02-2012, 06:46 AM
MPDano's Avatar
I use Castrol Dex/Merc for now. Once I reseal my Trannies, I think I may try something better but not sure what yet.
Old 02-02-2012, 06:58 AM
jdill
okay thanx here are a couple pics blue metalic with blue leather
Old 02-02-2012, 07:44 AM
European Shark
riber.bentsen's Avatar
Looks like a steal at a grand from here - and a non-sunroof car as well
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 02-02-2012, 08:01 AM
MPDano's Avatar
I agree as that looks very nice. We still need interior and engine pics as well. I still don't get the non-sunroof statement all the time as I LOVE my Sunroof.
Old 02-02-2012, 08:16 AM
Network Native
Danglerb's Avatar
Dexron VI seems popular these days, some like Mobil One, I think last thread got a vote for Torco. Important thing seems to be keeping it at the correct level.
Old 02-02-2012, 09:59 AM
