oil in upper intake plenium
new here,i was chasing a mis in my 85 928 32v and found oil in the intake manifold and was wondering if this normal,considering all the vacum lines that tie into it
Took mine off a while back during some maintenance and found a small amount in mine as well. I was assured by my car mechanic friend that it was normal. I cleaned it out and went on with the maintenance...
86 928S 98 Saab 900S Turbo |
Yes, perfectly normal. It is from a condition called blowback. Check out 928 Specialists - Dave sells a kit to remedy it, called a sharkvent.
Ed 85 928 5 spd (guards red over tan) 07 Shelby GT500 6 spd (torch red over two tone black and red leather) |
...also note however that if there are large amounts of oil, it could be an indication of a problem (bad rings, etc). Also check the various hoses running on top of the engine, especially at the oil filler neck, and make sure they are all on tight and clamped properly.
I put one of Carls Oil Baffles in my Euro, not sure if it's different in your 32v. As the others have said, it's normal to an extent. The question is how much oil are you seeing?
![]() 928 Motorsports - Porsche® Performance Parts - Oil Control Baffle For The Porsche® 928
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Network Native
Not just normal, but SNAFU, I'm convinced oil ingestion is a fairly serious problem with many 928's as oil promotes detonation. The whole breathing system could use some fixing, not sure which of the dodads like prefer yet, but that small vent looks too restrictive.
thanks for the help,ill make sure to get all the lines tight,and grab a baffle to help the blow-by,if that dont work then i guess ill be doing a head and re-ring, YE-PEEEEE
928 Newbie
Does that baffle work and does it fit the US 32v (85-86) ?
Architecture & Porsche's
It's already in your car. Factory part for later years.
Porsche Club Racing National Scrutineer '89 Andial 951 '82 928R '74 911 RSR 3.6 |
928 Newbie
Thanks Mark .. (Wshew.. My wallet just breathed a sign of relief..)
