mikeesik's Avatar
High perf. tires, without tramlining.
Looking for a set of tires not too soft and noisy.
Had problems in the past with the car following longitude ruts. HATE IT !!!
Have Cup 1's on the car with 225-45-17-/-255-4o-17 rear.
Anyone have tires with which you are satisfied about and never think of them when your driving?
Formerly from ratslist.
AMG E 55..2002.
Lotus Esprit SE. 1990
Old 04-03-2012, 03:46 PM
toofast928's Avatar
I have the Continental DW. 17" wheel, no tramming ride is perfect.
Tony B
1982 Blk/Blk
5.0L Hybrid
Blown 10 psi 500 HP
Old 04-03-2012, 03:58 PM
mikeesik's Avatar
What of road noise-wear-and in the wet?
Thanks for replying btw.
AMG E 55..2002.
Old 04-03-2012, 04:01 PM
stepson's Avatar
Mikesik,
Are these original stock Cup 1's? If not, check the offsets. I thought that tramlining was normally not a tire issue, but rather a wheel issue.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 04-03-2012, 04:06 PM
Pete R's Avatar
Bridgestone re760's.. awesome
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 04-03-2012, 04:10 PM
Network Native
Danglerb's Avatar
I'm think Kumho V700 or Hoosiers, hate that tramline with grooved pavement, but avoid patterns with straight lines.
Old 04-03-2012, 04:19 PM
mikeesik's Avatar
Is that a fact?
AMG E 55..2002.
Old 04-03-2012, 04:24 PM
mikeesik's Avatar
Originally Posted by stepson View Post
Mikesik,
No stepson, they're after market.
Thought that they'd be copies; at least of course in the offset department.
Is this from your experience? Thanks for the thought.
AMG E 55..2002.
Old 04-03-2012, 04:28 PM
Put in some Delrin rack bushings, they'll make a big difference and greatly reduce trammlining.
Old 04-03-2012, 06:52 PM
laneyamps's Avatar
I currently have Kumho Ecsta's on mine ...No issues to speak of...All I can say is that (for the last 3yrs) I've been very happy with them
84' 928S Black/Black
Old 04-03-2012, 09:11 PM
Network Native
Danglerb's Avatar
Originally Posted by mikeesik View Post
Is that a fact?
I had a set of Dunlops with the straight grooves, terrible.
Old 04-03-2012, 11:20 PM
19psi's Avatar
I really like my Hankook Evo V12 tires. They've never gotten squirrely under any kind of road conditions and Indiana can have some really sucky roads come spring time. On black asphalt they are silent but on lighter color aged highways and concrete bridges they can get rather loud. My 928 is one of those cars I can let go of the steering wheel without fear of it darting from grooves or ruts.
I'm running 235/35-19 up front and 265/30-19 rear. Not very expensive either at less than $250 each.
George in Indiana
928 Weissach #153
Cayenne S
Old 04-04-2012, 08:21 AM
stepson's Avatar
No personal experience, I run stock Porsche wheels with correct offsets. Just passing on others' experiences.
Old 04-04-2012, 09:19 AM
Pete R's Avatar
that's funny.
Neon SRT4 track car
Old 04-04-2012, 09:28 AM
928-Electrics Guy
Alan in AZ's Avatar
It is motre likely to be the wheels (offsets) than tires, though wider section tires may also have an effect as will badly worn tires if the alignment is off (e.g. unevenly worn on the inside or outside).
I'd check the wheel offsets compared to stock.
Wheel offsets on aftermarket are all over the place - and were very different for 928, 911 etc
Alan
1994 928 GTS Black/Black Manual
Old 04-04-2012, 01:51 PM
928 Newbie
dcrasta's Avatar
928 front offset is 65 ET- IF you are using aftermarket wheels with 59ET or less you car will be more sensitive to Tramming .
Also your alignment (front and rear) can have adverse effects, and if your ride height is lower than stock, you could be introducing excessive rear camber (negative).
If you have the option try a set of factory wheels. If not, get your ride height and alignment checked.
Old 04-04-2012, 05:16 PM
