jdill
later on in the thread my 928 will start looking like this ,,,,,and you will learn about painting from the ground up
79 928 euro -lint green/black leather 5 speed
Old 04-25-2012, 04:42 PM
Kool
AirtekHVAC's Avatar
Sweet! The nuts are a neat feature, I guess only certain models have that?
Definitely interested in the body work. I have never done any, and want to learn and do all the prep work on mine when the time comes...
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 04-25-2012, 06:56 PM
Stoolie's Avatar
Looks like the filter is doing its job!
1991 928 S4 - Horizon Blue
Old 04-25-2012, 08:35 PM
american-kiwi's Avatar
Stoolie...be happy you live in ChCh. (apart from the earthquakes)..lol
..believe me..pack rats (woodrats) are a pain in the you know what!!...they hide cr@p in your car (tons of it)....eat up all the wiring and anything rubber or plastic under the hood...where i live now..i have to keep the hoods open at night..or im in trouble the next morning....like...my car wont start!
John .........
1978 Porsche 928 5sp LSD
1982 porsche 928 5sp LSD
Old 04-25-2012, 10:55 PM
Dan951's Avatar
Nice work!
Old 04-26-2012, 12:10 AM
jdill
okay I managed to make a little progress,,,i took off the hood and started removing paint,,first you have to remove the washer jets, and the wire goes through a round plastic cap that closes out the washer jet holes,so you need to remove the plug in order to slide it through the holes
Old 04-28-2012, 04:23 PM
jdill
this tool is a must for a 928 owner
Old 04-28-2012, 04:24 PM
jdill
push in the sleeve that fits in the hole as far as you can and it releases the tabs and you can remove the wire
Old 04-28-2012, 04:26 PM
jdill
its a good idea to label the slots but it is not critical because the wires on the other side of the plug are the same color[
img]http://forums.pelicanparts.com/uploads20/0121335655684.jpg[/img]
Old 04-28-2012, 04:29 PM
jdill
so with the washer jets out and the emblem removed its time to start removing the old finish
Old 04-28-2012, 04:31 PM
jdill
I scratch up the surface with some 36 grit so the stripper attacks faster and put on my first heavy coat
Old 04-28-2012, 04:33 PM
jdill
the first coat reacts quickly,,, a sure sign it is not factory paint
Old 04-28-2012, 04:36 PM
jdill
after scraping off the first coat i can see the factory paint
Old 04-28-2012, 04:38 PM
jdill
so now the factory paint gets removed as it softens it will not curdle as it is lacquer and just turns to soup,,,,thats the second coat removing the factory paint
Old 04-28-2012, 04:42 PM
jdill
now the third coat of stripper and we are removing the epoxy primer and the etching primer so these products are the base of the paint job
Old 04-28-2012, 04:46 PM
jdill
so another scrape and your at the aluminum
img]http://forums.pelicanparts.com/uploads20/0301335656850.jpg[/img]
Old 04-28-2012, 04:50 PM
jdill
the last pic is just another coat of stripper around the edges,,, it is better to remove all the paint with the stripper so you dont damage the aluminum with sanders the hood will distort very easy with machines heating it up,,, So the last step is to use a scotch brite with some water and nuetralize the stripper and clean off the hood,,,
now we are on our way to a new finish,,,,,, the next segment will be removing the trim from the doors and the wiring for the mirrors....
Old 04-28-2012, 04:56 PM
You should have used a peace of plastic sheeting to cover the stripper up after you had put the stripper on the hood . It keeps if from drying out and helps it remove the paint so you do not have to reply it again . Plus you must have gotten the paint stripper on the underside of the hood with no tape and paper around the edge of the hood that i could see in the pic.
The beast 1984 928s twin turbo 5speed LSD/ 508.6RWHP 495RW ft lbs 12.5 psig manifold pressure, MS2 and EDIS-8 nikasil block JE 2618 pistons (TripleT). 2001 AUDI A6 4.2 chip 320 hp. 2002 CHEV Tahoe 4wd. 1971 sonett race car GT4 National Champion now GTL class car sold. The words of a Ford GT man. ( Damit i need to get some turbos)
Old 04-28-2012, 05:03 PM
jdill
Thank you for your advice mark,,, I have never used plastic sheeting over stripper and I never have a problem with the stripper drying out,as far as the underside of the hood ,i didn't get any stripper under there because i was only stripping the top,,but i do strip the underside as well,, i don't strip where the insulator goes or the emissions label due to the fact the seam sealer would be compromised,,,otherwise all the paint comes off and we start from scratch.....This thread is an actual body & paint restoration for viewers to know the difference between a 3k paint job and a 20k paint job,,,I'm trying to show the extent of doing something right while giving basic instructions for the do it yourselfer.
A car prepared correctly will have a paint job that will last 20 plus years, providing all steps are followed and product is not compromised,,, tI'me and labor is intense,,,patience and knowledge will win shows and recognition.
Anything else is a band-aid,a cosmetic cover up,although if that works for you then great,,, there is a job for every budget,,,the type of work i am demonstrating is not for everybody,,,it is for people interested in the preservation for classic automobiles...
Old 04-29-2012, 04:47 AM
hey,
I am not trying to discredit you or your work . I was just stating. Plus you pay for what you get....... Everyone knows that......
Old 04-29-2012, 06:03 AM
