DannyBNH's Avatar
Radio issue
I'm almost embarrassed to ask this one...
Since I got the car it's had radio issues.. ( not working)
So here I have a Sony CD player I bought
I have accessory/Power lines marked and connected.
Looks like I have
From the car:
Red & Red/white
Brown & Brown/White
On the CD Player:
Speaker wires
gray / gray/black (L +/-)
White / white/black (R +/-)
My antenna wasn't working so I bought a new one... No difference. My cable is bad (probably by a mouse ) so instead of removing everything to dig it out I got an under dash antenna from Crutchfield.
Anyway, I can get the radio/cd to play but it gets scratchy after 10 or 15 minutes and I have to power off/power on.. and that sometimes doesn't bring it back.
I also have to connect the power antenna line for the ( not connected ) power antenna to get any sound at all.
I've looked at the wiring diag but the colors aren't marked, and I stink at wiring.
The fader next to the drives side I'm sure comes in to play somehow also..
Any help is appreciated... My commute to Mass starts tomorrow... No tunes is a bummer..
-Dan
1979 Porsche 911 Black on Black widebody 3.2 - SOLD
2015 Jeep Wrangler Sport Unlimited - White
1984 Porsche 928s Black on Black - SOLD
Old 06-24-2012, 11:27 AM
harborman's Avatar
Well, sounds like not a stock radio for one. Not sure but mine came with Blaupunkt.
Did yours have a stock Blau amp mounted in the pod by passenger seat??
I replaced my original with a JVC touch screen. I had to bypass the original power amp, fader control and wire speakers directly to new unit.
I kept the antenna in windshield and associated stock antenna amp. Your under dash antenna?? Not sure about this! Could be one problem.
Sounds like you have a heating problem if it quits after 15 minutes. Are you sure the radio is good? Maybe bench test the radio and let it run to see if heat problem.
You need a DC volt/ohm meter to check connections and voltage to radio. Get one at Lowes or Radio Shack, real cheap.
Since I can balance speakers with my JVC I bypassed the fader/balance control by drivers seat. I was able to do the bypass in the pod where the amp is. Maybe all your speaker connections come in there like mine did, but I have a 86.
German color codes a bit different then American. But I doubt any are standard anyway.
Hope this helps you some.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 06-24-2012, 12:12 PM
harborman's Avatar
Just looked at my notes on radio install. On my 86.....
Left speaker : Red +, Brown -
Right : Red/Wht +, Brown/Wht -
Constant Positive + voltage = Red from Ignition SW.
Brown = Negative
Antenna Amp = White
1986 928S
32 valve engine
Old 06-24-2012, 12:23 PM
DannyBNH's Avatar
Thanks I'll try that. Earlier you mentioned hot. The radio get's very hot in the back.
time to call Crutchfield... Hope it's still under warentee
Old 06-24-2012, 12:58 PM
DannyBNH's Avatar
I had the wiring incorrect. But after testing it ou tof the car
after 20 minutes still gets staticy and toasty.. It's on it's way back to the manufacturer to fix..
Thanks Harborman
Old 06-24-2012, 02:21 PM
harborman's Avatar
Thanks Harborman
Well, Maybe we pined it down. Anyway, Hope we have the answer. It may run hot under full load, but did it go into distortion. Give it a full load for an hour or so, as long as not beyond it's specs. Sounds like it may be defective. Return it if you can and are sure it's the CD/Radio. Good luck!
1986 928S
32 valve engine
Old 06-24-2012, 05:03 PM
