-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   Coolant gauge question (is it working?) (http://forums.pelicanparts.com/showthread.php?t=689444)
Mpierick 07-17-2012 06:33 PM
I am terrible when it comes to electrical troubleshooting.
My coolant gauge is not registering. I have taken the plug off at the engine water bridge and ground the blue wire and the gauge will register hot. I then ground the brown and the alarm light will light on the gauge. I tested the resistance between each terminal blades of the sensor to ground. Nothing registers on the meter. When I put the plug back on the sensor the gauge will not work.
I have also replaced the sensor.
I hope I explained my problem well enough.
Thanks. Mike P
Dean_Fuller 07-17-2012 07:23 PM
Try cleaning the grounds under the steering column.
Mpierick 07-18-2012 04:10 AM
I will clean the grounds when I get home tonight.
Where is the needle on the gauge suppose to be pegged at normal running temperature?
Thanks. Mike
Mpierick 07-18-2012 04:37 PM
Dean, I cleaned the grounds behind the dash. Not an easy job. I am tall. Still not working.
What else can I do?
Thanks for the help.
