pumpkinhead's Avatar
Alt?
So here's the story, I left for work and all was fine. stopped at the gas station, and when I started the car back up the central warning light came on along with the OXS light and the alt light. and the gauge was only reading at about 9 volts, it usually reads at about 13, so am I right to think the alt. went south? My car is an 82, any other suggestions ?
Old 08-26-2012, 04:08 PM
Maleficio's Avatar
Use a multimeter to check the charging voltage while running.
Old 08-26-2012, 06:17 PM
Petie3rd
Mrmerlin's Avatar
check the 14 pin connector under the hood maybe its corroded and the alternator isnt charging
the exciter wire goes through the 14 pin
Old 08-26-2012, 08:01 PM
A.J.
tychain99's Avatar
mine did the same thing as my alternator was dying... oxs sensor and stop lamp. It was a brand new battery, so i didnt consider it was the alt until it died out on me . but I would listen to those guys before your deal with pulling that thing off. SUCH A PAIN . that alt weighs like 30 pounds and if you dont have a lift or jack stands you will want to cry ...
1980 auto- cashmere beige
1984 auto- black on black
Old 08-26-2012, 08:07 PM
82 928 euro atm/lsd
just changed had my alt checked and had a similar problem gauge was reading 9v but when i checked it with a charging meter it read 13 1/2 volts. i found out theres a resistor in the back of the cluster that works the gauge. thats whats wrong. i have a 79 5sp im not sure if there the same set up
1979 928 5 speed 90k
Old 09-03-2012, 08:30 AM
MPDano's Avatar
Ugh. Shoulda checked voltage at the front post first before buying another Alt. You gotta spare now.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 09-03-2012, 03:34 PM
