-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   window stuck (http://forums.pelicanparts.com/showthread.php?t=707860)
tychain99 09-23-2012 05:58 PM
window stuck
window is stuck up right now.. for a while the window would stop working for a little bit. every now and then it would be stuck up, or down, but never for more than an hour or two.
the last few times i have taken the car out, the window wont move.. where is the best spot to start?
motor, switch ?
Maleficio 09-23-2012 09:44 PM
Open and close the door slowly while depressing the switch. If the motor energizes, then you have a broken wire in the door. If not, then your switch is probably toast.
tychain99 09-24-2012 04:57 AM
clever... i will check that and report back
harborman 09-24-2012 06:38 AM
I will bet on the switch, had to replace both in my 86. If you are needing a switch, I would go ahead and replace all 4 while at it.
tychain99 09-27-2012 05:07 PM
not the switch.... door trick worked... although it looks a little ghetto when i roll up to a stop sign and open the door to get the window down....
how much dissection involved to get to the rebel wire?
i can get door panels off not sweat,. but don't the wires come through some plastic tubing or something
Maleficio 09-27-2012 05:41 PM
The wires come from a connector just under the dash on the outboard driver side and through a plastic conduit into the door. You likely have a broken wire but with good insulation. Just slowly work the wire with your fingers until you find a soft/loose spot. That's the break. Cut out the bad part, splice it back together just I showed in my wire repair thread. Check all of your wires while in there.
tychain99 09-27-2012 09:45 PM
good call... I took door panel off a while ago because the lower carpet was loose. I used a little 3m, stuck it back on, and shortly after realized my power mirrors did not work... possibly the same issue?
Maleficio 09-27-2012 10:02 PM
Very possible, but those mirror switches are crap and expensive.
Maleficio 09-27-2012 11:55 PM
However, the wiring for the mirrors resides much higher than the door carpet.
Just pull the panel and re-work the wiring. You may need to run all new wiring. Just depends on how much effort you're willing to expend.
lfausty 10-02-2012 04:56 PM
and before you hear a rattling around in there the 10mm ? screws plate that the metal tubes run through have a look if the screws are loose, the window starts to slowly unbalance , causing undo stress on the switches,rubber,felt,window scratchys...., youll want to be rolling up fast and even as possible vs any struggle.
Maleficio 10-02-2012 05:32 PM
Very true. Mine were loose or laying in the bottom of the door.
