A.J.
tychain99's Avatar
window stuck
window is stuck up right now.. for a while the window would stop working for a little bit. every now and then it would be stuck up, or down, but never for more than an hour or two.
the last few times i have taken the car out, the window wont move.. where is the best spot to start?
motor, switch ?
1980 auto- cashmere beige
1984 auto- black on black
Old 09-23-2012, 05:58 PM
Maleficio's Avatar
Open and close the door slowly while depressing the switch. If the motor energizes, then you have a broken wire in the door. If not, then your switch is probably toast.
Old 09-23-2012, 09:44 PM
A.J.
tychain99's Avatar
clever... i will check that and report back
Old 09-24-2012, 04:57 AM
harborman's Avatar
I will bet on the switch, had to replace both in my 86. If you are needing a switch, I would go ahead and replace all 4 while at it.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 09-24-2012, 06:38 AM
A.J.
tychain99's Avatar
not the switch.... door trick worked... although it looks a little ghetto when i roll up to a stop sign and open the door to get the window down....
how much dissection involved to get to the rebel wire?
i can get door panels off not sweat,. but don't the wires come through some plastic tubing or something
Old 09-27-2012, 05:07 PM
Maleficio's Avatar
The wires come from a connector just under the dash on the outboard driver side and through a plastic conduit into the door. You likely have a broken wire but with good insulation. Just slowly work the wire with your fingers until you find a soft/loose spot. That's the break. Cut out the bad part, splice it back together just I showed in my wire repair thread. Check all of your wires while in there.
Old 09-27-2012, 05:41 PM
A.J.
tychain99's Avatar
good call... I took door panel off a while ago because the lower carpet was loose. I used a little 3m, stuck it back on, and shortly after realized my power mirrors did not work... possibly the same issue?
Old 09-27-2012, 09:45 PM
Maleficio's Avatar
Very possible, but those mirror switches are crap and expensive.
Old 09-27-2012, 10:02 PM
Maleficio's Avatar
However, the wiring for the mirrors resides much higher than the door carpet.
Just pull the panel and re-work the wiring. You may need to run all new wiring. Just depends on how much effort you're willing to expend.
Old 09-27-2012, 11:55 PM
1982 928 us
and before you hear a rattling around in there the 10mm ? screws plate that the metal tubes run through have a look if the screws are loose, the window starts to slowly unbalance , causing undo stress on the switches,rubber,felt,window scratchys...., youll want to be rolling up fast and even as possible vs any struggle.
1982 Porsche 928 us
Old 10-02-2012, 04:56 PM
Maleficio's Avatar
Very true. Mine were loose or laying in the bottom of the door.
Old 10-02-2012, 05:32 PM
