928 transmission fluid
I have a 1981 automatic 928. The hose from the transmission to the radiator blew this summer. After 2 months of looking for a replacement part I finally got a new one made. My problem is I do not know where to put the transmission fluid in the car. There is a picture in the owners manual but I can't find the real place to put it in. Since the car can't be moved I can't take it anywhere.
please help
Dave
Old 11-07-2012, 06:43 AM
MPDano's Avatar
Tranny Fluid is put into the reservoir on the passenger side of the transaxle (near the rear). You'll need the car up on stands and running to do this properly. You'll need some sort of pump to get the fluid from bottle to reservoir. I use a manual pump bought at the local parts store.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 11-07-2012, 07:12 AM
Pete R's Avatar
best $8 I ever spent
Multi-Use Transfer Pump
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 11-07-2012, 08:33 AM
Kiln_Red's Avatar
You may not be seeing the reservoir because it is probably coated in grease. It is a small reservoir that is mounted on the right side of the transmission. It has a red cover threaded to the top of it.
Old 11-07-2012, 02:32 PM
DZGunner's Avatar
Where did you get the hose made, i currently have a hose with a hole in it and would really like a solid piece.
It also i think is the one that goes from the radiator to the trans.
Old 11-07-2012, 06:56 PM
MPDano's Avatar
Went through two of those already. For some reason mine only last for about 10 uses. I was just at HF today getting my Plastic Welding gear. Shoulda picked me up another.
Old 11-07-2012, 07:47 PM
Dozman's Avatar
Pick up a a hand pump pressurized pesticide sprayer 1-3 gallon capacity. Can adapt a hose to it, ot light heat the plastic wand, and shape it to a slight u bend.
Just use it for trans...
$20 maybe. Lasts as long as you take care of it.
'88 S4
Old 11-07-2012, 08:28 PM
928 Newbie
dcrasta's Avatar
The front hose can be replaced by using a dremel and cutting off the sleaves that crimp the hose on the barbs.
I used a transmission line kit from Autozone (Metric 10mm) and Fuel Injection clamps. THe front section does not need the heat resistance the mid and rear sections need, and this has worked well for me.
If you are on Rennlist look in my Galery (or register on rennlist and look at my gallery album (dcrasta)) Took me 1 hour to do. I had the use of a lift however you can jack the front of the car up to do this.
You will need to top off the fluid once you are done .
Old 11-08-2012, 11:53 AM
I went to a local truck repair place and they made me one copying the old one. Charged me $34 which wasn't bad I thought.
Old 11-20-2012, 10:40 AM
