1982 928S
georges 928S's Avatar
RE:head lights dont flip up
HI GUYS, having problems with head lights, they come on but dont flip up. what could be the problem. Thanks Ed.
Old 12-01-2012, 05:21 PM
harborman's Avatar
Obvious things first, check fuses, relays. Then limit switches and power to head light motor.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 12-02-2012, 05:42 AM
Kool
AirtekHVAC's Avatar
Mine was relay...
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 12-02-2012, 06:34 AM
laneyamps's Avatar
If it's none of the above problems (fuse, wiring, or relay), pull the headlight motor out! Remove rubber protective boot, and open up the motor (just a few Philips screws) and clean all the rust off the headlight motor disc.
I pulled my hair out for a couple weeks, retracing wiring, OPENING relays, rechecking all fuses, etc, before I finally opened up the headlight motor. Found a ton of rust on the motor disc. (in both the UP & DOWN positions) I wet-sanded the disc with rust-buster solution, and emery cloth. My headlights never worked so good!
84' 928S Black/Black
Old 12-03-2012, 07:37 AM
1982 928S
RE: head lights
Hey Guys, how can i remove the head light motor , the plug is stuck behind it and i don't want to force it out. pictures will be nice. Thanks Ed.
Old 12-03-2012, 05:38 PM
laneyamps's Avatar
You have an '82, right?
There's 4 terminals going to the headlight motor plug....They have those "pain in the ass" terminals that "click" or "snap" together. You need a tiny ice pick, or "awl" to remove each of the 4 terminal wires going to the headlight motor. Pull back the rubber, and you'll see exactly what I'm talking about. Take the awl, and put it in each hole of each wire terminal, and pull at the same time. Can only do one at a time.
Chris
Old 12-06-2012, 11:08 AM
1982 928S
RE: Head light
Thanks Chris, problem is the 4 plug wire is stuck between radiator and head light motor and iam afraid to pull on it hard, thats why i need to know how to remove the motor. Thanks. Ed.
Old 12-06-2012, 06:42 PM
davetr's Avatar
same problem w mine, iv not started working on it yet
Old 12-07-2012, 04:07 AM
laneyamps's Avatar
OK, I gotcha'
Mine was a piece of cake to get to....But, then again, my radiator is not that old, so, maybe whoever installed it, re-routed the wires????
Or, maybe an 84 is set up a tad differently???
Old 12-07-2012, 01:46 PM
1982 928S
RE: Head light
chris, i still need to know how to remove the head light motor so i can remove the plug, anyone done that please chime in. Thanks Ed.
Old 12-08-2012, 07:26 AM
Petie3rd
Mrmerlin's Avatar
to remove the HL motor,
first mark the arm to the shaft,
then remove the arm nut,
then mark the motor attachment bolts there are 3 of them,
then remove these the motor will come off its mount.
Old 12-08-2012, 10:30 AM
laneyamps's Avatar
Ooops! Sorry! As Mrmerlin mentioned, just remove the 3 mounting nuts/bolts & the arm nut. The motor will just drop right out. If you have a set of 1/4" drive sockets & ratchet, and a screwdriver to pry off the arm, you're good to go.
Old 12-08-2012, 12:15 PM
1982 928S
RE: Head light
Thanks Stan and chris, i will try that and let you guys know. Ed.
Old 12-08-2012, 07:02 PM
