-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   my 81 928 won't start...help (http://forums.pelicanparts.com/showthread.php?t=761681)
MPDano 07-23-2013 06:54 AM
Originally Posted by 81headache (Post 7564403)
will try rocker swtich and get some pics of engine
Cool :cool:
81headache 07-23-2013 08:47 AM
http://forums.pelicanparts.com/uploa...1374593992.jpg
http://forums.pelicanparts.com/uploa...1374594191.jpg
ok fuel pump comes on and seems to be working my friend the mechanic says he thinks its possibly not getting a pulse to fuel injectors I have already replaced the fuel injector relay any ideas why else they wouldnt be delivering fuel http://forums.pelicanparts.com/support/smileys/wat6.gif
MPDano 07-23-2013 08:53 AM
L-Jet for sure.
MPDano 07-23-2013 08:55 AM
buy a noid light at the local auto parts store to verify injectors are getting the power. If not, Green Wire is in your future.
928 International-Distributor Wire 78-84-green
http://www.mailordercentral.com/928i...2860290700.JPG
Write up is in the "Common Fixes" Thread.
81headache 07-23-2013 09:13 AM
why so expensive
MPDano 07-23-2013 09:14 AM
Originally Posted by 81headache (Post 7564649)
why so expensive
One word: PORSCHE SmileWavy
81headache 07-23-2013 09:20 AM
thanks appriciate the help will keep posting results
MPDano 07-23-2013 09:30 AM
Also the Noid Light tester is pretty inexpensive and they come with adapters to fit all size injectors. I think I paid less than $10 for mine at Autozone.
OEM/6 pcs. noid light set (27161) | Injector Signal Tester | AutoZone.com
http://contentinfo.autozone.com/znet...27161/image/4/
81headache 07-25-2013 07:22 AM
so green wire will prevent injectors from firing
also has anyone succesully rebuilt this wire as money is an issue at this time in project just wanna get running and get it home
MPDano 07-25-2013 07:54 AM
It's been discussed and supplies researched. In the end, just buy the one I posted.
Sometimes, and very rare, someone might have a spare used one that works. At least to get you home.
neil30076 07-25-2013 08:37 AM
also has anyone successfully rebuilt this wire as money is an issue at this time in project just wanna get running and get it home
Signal on green wire tells the control unit the engine is running, this signal triggers the injectors; check the connector at the ecu end of the wire, that is the one farthest from the distributor, by the 14 pin. If you are lucky, its falling apart and you can make a temporary repair there - pull the pins carefully out of what probably is a very brittle connector and insert into the other half. Make sure you match them pin for pin. If the cable is brittle or broken you are s****d, time to but a new one.
1982_928 07-25-2013 10:33 AM
..Does it have enough gas in it? (I know this is a different car, but still...) My Mercedes 190e would start and run for a second, and die.. It had just enough gas in it to start for a second.
I decided to check how much gas was in it after I bought a fuel distributor and fuel pumps... Damnit.
How long has it been sitting at this shop? How rotten does the gas smell if you pull the gas cap and take a whiff?
81headache 07-31-2013 06:29 AM
my green wire should be here today and possibly installed tomorrow keeping hopes up and fingers crosssed
MPDano 07-31-2013 06:58 AM
Use the common fixes thread pics as a guide. There will be a piece you'll need to remove on the Disty end of the wire. Take your time on this.
81headache 08-02-2013 07:53 AM
ok green wire installed still only starting and running for a couple seconds on starting fluid gonna check to make sure fuel is getting to injectors later today any other suggestions i can hear the fuel pump come on when i turn the key
MPDano 08-02-2013 08:11 AM
Noid as already suggested.
81headache 08-02-2013 09:03 AM
sorry didn't see the noid before what is it
MPDano 08-02-2013 09:08 AM
Tells whether your injectors are getting power. No power, injectors wont let fuel through.
They will blink while cranking.
81headache 08-02-2013 11:30 AM
hooked noid sensor up and we are getting no light there is power getting 12volts to injectors but no pulse to fire injectors. there is also fuel in the fuel rail and i already replaced fuel injector relay any ideas where to go from here
MPDano 08-02-2013 12:01 PM
Have you gone through all your grounds? I believe there is a chart in the common fixes thread. Verify all the other injectors with your noid
