-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=15)
-   -   Odometer step motor test. (http://forums.pelicanparts.com/showthread.php?t=807270)
Yoni_d 04-20-2014 08:00 AM
Hi guys,
My odometer stopped working so I took it apart and noticed that all the gears were in place but the step motor gear was not aligned correctly so it simply stuck. I have mounted it correctly but before putting it all back together in the car I wanted to test if the step motor working correctly.
Is there any way to "manually" operate this step motor in some way?
I just dont want to put the instrumental panel back in the car and then find out that it is not working correctly.
Any ideas?
Thanks!
AirtekHVAC 04-20-2014 02:47 PM
There are a few threads out there, with Dwayne's garage having one of the better ones...seems like you might have to shim it...Google Dwayne's garage....
Yoni_d 04-20-2014 10:28 PM
Thanks! I will have a look..
paalw 04-21-2014 01:49 PM
Hi.
Check out this thread, a lot of info on the subject, including how to test motor.
Odometer not working, gears intact. - Rennlist Discussion Forums
Paal
Danglerb 04-22-2014 12:03 AM
I would not go to the trouble of taking it apart and not replace the known failure gears.
Yoni_d 04-22-2014 04:33 AM
The gears were replaced about a year ago with new ones. The problem was not a broken gear but a bad alignment of the step motor so the gears couldnt be moved.
