Odometer step motor test.
Hi guys,
My odometer stopped working so I took it apart and noticed that all the gears were in place but the step motor gear was not aligned correctly so it simply stuck. I have mounted it correctly but before putting it all back together in the car I wanted to test if the step motor working correctly. Is there any way to "manually" operate this step motor in some way? I just dont want to put the instrumental panel back in the car and then find out that it is not working correctly. Any ideas? Thanks!
Porsche 928S 4.7L 1980 European redhead
Kool
There are a few threads out there, with Dwayne's garage having one of the better ones...seems like you might have to shim it...Google Dwayne's garage....
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
Thanks! I will have a look..
Hi.
Check out this thread, a lot of info on the subject, including how to test motor. Odometer not working, gears intact. - Rennlist Discussion Forums Paal |
Network Native
I would not go to the trouble of taking it apart and not replace the known failure gears.
The gears were replaced about a year ago with new ones. The problem was not a broken gear but a bad alignment of the step motor so the gears couldnt be moved.
