SanDiego928's Avatar
P Steering Changed Suddenly
My steering became harder all of a sudden when entering the freeway after rounding an on ramp.
Checked hoses, belt, reservoir. Had my son turn steering back and forth and I saw no movement of fluid in reservoir. Fluid is about 1.5 inches from top of reservoir.
Is there any way of telling if it is the pump? Pump was rebuilt July 2013.
Thanks.....
Mark
1981 928
Old 07-12-2014, 12:31 PM
Network Native
Danglerb's Avatar
Funky pumps usually make a noise. Flow should be obvious looking in the reservoir, I think anyway.
Old 07-12-2014, 09:46 PM
harborman's Avatar
If fluid looks good and up, no leaks in system, belt is tight, it may be the pump. Rebuilt pump may be the problem.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 07-13-2014, 06:23 AM
thanks guys. seems to be the pump but I would think it would make some kind of noise yet no noise at all.
Mark
1981 928
Old 07-13-2014, 09:02 PM
European Shark
riber.bentsen's Avatar
Try changing the fluid first, it might cure it. Like an automatic transmission slipping because the oil looses viscosity over time.
Old 07-14-2014, 03:58 AM
harborman's Avatar
I think my 928 uses trans fluid in the power steering. You might want to double check on that!
1986 928S
32 valve engine
Old 07-14-2014, 06:28 AM
European Shark
It does, all 928's do. Dexron III ATF.
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 07-14-2014, 11:26 AM
thanks, Yes auto trans fluid and 1 year old.
Mark
1981 928
Old 07-14-2014, 06:05 PM
Petie3rd
Mrmerlin's Avatar
do you have a steel reservoir or the plastic version?
Old 07-14-2014, 08:30 PM
Steel I believe. Top is metal, long threaded stem in the middle. Nice metal thumb screw looking thing, kind of neat. Always think I am gonna drop it somewhere in the bay unscrewing it.
Didnt even know there was a plastic one.
Mark
1981 928
Old 07-14-2014, 09:09 PM
