1980 oxygen sensor wireing hook up
Hello 928'ers 1980 Porsche 928 us model
Can anyone tell me about the wiring hook up at the " oxygen sensor "
Mine I was unable to unhook . It looked like the wire was crimped on and as such I had to cut it in 2 about 2 inches up from the oxygen sensor .
Is that a single wire ? or a wire inside a Grounding type shield on the outside of the
oxygen sensor wiring ???
I looked at the wire but it looks like a single wire but I may be mistaken .
Can I just make a new connection to this wire
Or is is a wire " inside " of a Grounding outer shield wire .
Thanks if anyone Knows
Old 08-16-2014, 08:45 AM
19psi's Avatar
Don't you have a plug connector inside the car at the CE panel?
George in Indiana
928 Weissach #153
Cayenne S
Old 08-16-2014, 10:07 AM
Network Native
Danglerb's Avatar
Many use a universal replacement that you splice/crimp onto the old connector. The actual connector is near the CE panel and looks a bit like a radio antenna connection. Sensor itself is the same afaik.
Old 08-16-2014, 02:51 PM
I did not trace it down but i believe that's correct
I am simply trying to find if It's only 1 wire or rather a wire inside a Ground Shield .
Thanks for reply
Old 08-18-2014, 08:55 AM
Yes ! I have seen those on the net >> " Mine " the one on the car looks like it was just crimped on .
I am simply trying to find if It's more then 1 wire ? OR a wire inside a Ground shield .
Thanks for reply
Old 08-18-2014, 08:58 AM
19psi's Avatar
Unplug the connector inside the car and see if it has two terminals. I'm guessing your '80 won't have the heating element version which requires additional wiring.
George in Indiana
928 Weissach #153
Cayenne S
Old 08-18-2014, 04:07 PM
