1985 Porsche 928s
Window switch wiring
I'm installing new (URO) window switches. The colors of the wires are different for two of the wires and the soldered connections on the back of the switch are slightly different, so it's not 100% clear which wire connects to what.
The wiring harness has red, brown, black and green wires and the new switch has red, brown, blue and yellow wires. I assume the red and brown wires connect (or do they?) but what about the blue and yellow?
Old 07-11-2016, 09:16 AM
stepson's Avatar
Where did the window switches come from?
In other words, ask the vendor that sold them to you for direction.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 07-11-2016, 12:17 PM
harborman's Avatar
If the switch is a double pull, double throw, all 4 wires are needed. Take an ohm meter and check your new switch to determine which wires are connected when the switch is operated. Without looking at it, the switch might be switching both 12V and Ground.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 07-13-2016, 05:00 AM
1985 Porsche 928s
The new switch is a URO unit from Roger. I used an ohm meter on the old switch to figure out which circuits were closing according the the switch position. Here are my findings for my '85;
Old Black = New Yellow
Old Red = New Red
Old Green = New Blue
Old Brown = New Grey
Here's what the plug on the end of the switch pigtail wire looks like now;
Old 07-14-2016, 09:49 AM
Network Native
Danglerb's Avatar
Weak memory here, but how many kinds of switches are there? Is it early and late model, plus a cheap aftermarket version?
Old 07-16-2016, 12:27 PM
harborman's Avatar
I replaced all window switches and I think they are the same, but the rear wiper switch might be different and I now need to replace it.
1986 928S
32 valve engine
Old 07-17-2016, 06:08 AM
