Odometer/Trip Meter
My odometer and trip counter stopped working on my Turbo S; speedometer works fine.
It's probably one of those plastic gears. Since I don't know which one it is, is it possible to buy a set of gears and how hard of a repair is it |
https://www.youtube.com/watch?v=9E-2uAQ5I14
Careful, if you break the very fine wire that the needle is mounted on, you get to buy a new speedometer. There are several different gears depending on whether it reads kilometers or miles.
Good luck, George Beuselinck |
I replaced the gear in mine see this post.
Sox https://forums.pelicanparts.com/porsche-944-turbo-turbo-s/897089-one-thing-leads-another.html
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
I just did this repair last week, after removing the speedo, disassembling and counting the gear teeth, I was able to find an .stl file for the gear I needed and 3D printed a new gear.
That is one option, although Pelcan also sells several different gears https://www.pelicanparts.com/cat/r_944m/elgage_odometer-gears?srsltid=AfmBOopls6qyxM3WINYA3o7k9P2zSFNCRdey Jtu2Awoa6eqqICO6TVOY |
Banned
There are several different gears , careful not to break a plastic
Edreadas has a great vid showing how to replace the gear:
https://youtu.be/9E-2uAQ5I14?si=ekc6CGTshlRT9QUD
-- '87 Diamond Blue Coupe -- '92 Miata -- '06 Scion XB (the wife's) -- '01 Audi S4 (Sold) -- '17 Tesla Model S60 |
