Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Rod Bearings
What is the spec I saw 75+ 5 or something not too sure. What type of oil or grease to use when installing them. Tips or comments would like!
Thank you! I want to do this correctly
Old 02-25-2014, 10:58 PM
If you're talking the torque for the rod bolts, the spec is 75+5 Nm (55+4 Lb-ft). Use only the ribbed rod nut, not the smooth surface ones. Use assembly lube. Of course, use plastigage to check for clearance between rod bearing and crankshaft.
Good luck, George Beuselinck
Old 02-26-2014, 07:08 AM
I have an 87 turbo with 80K miles (approx.). The oil pan gasket needs to be replaced.
Should I replace the rod bearings at this time? How can I tell they need replacement?
Is this work difficult? I have not been able to find instructions on this forum or Clark's Garage.
Thank you for any information you can provide.
raulg
Old 03-02-2014, 09:08 AM
raulg
That would be wise. I wasnt originally planning on it, but once you get the pan off, you'd be looking at at all that stuff. I did the bearings, a bunch of suspension work, inner and outer tie rods. All that stuff was original. I figured since I was there... As for the work, with the right tools no it aint too difficult. I say this because this isnt my daily driver, so I wasnt under the gun to finish it in one weekend. I did mine with help from this forum. There are a few threads on that topic. Just search it out...
86 951 blk
Old 03-02-2014, 04:20 PM
Start here... I know it says cylinder head, but the latter pages are for the pan removal.
http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/619657-cylinder-head-job-photos.html
86 951 blk
Old 03-02-2014, 04:31 PM
