Remove ABS Pump, Bleed Necessary?
I am cleaning up a bunch of surface rust in the front trunk under and around the battery. It extends below the ABS pump. If I undo the hard lines, do I need to re-bleed the brakes?
Old 07-10-2019, 06:52 PM
Yes, very much so.
Old 07-11-2019, 06:32 AM
That's what I thought. Due to the location, I'm assuming that I might as well just do a complete fluid change to ensure it's bled properly?
Old 07-11-2019, 09:12 AM
