HELP Turn key no power no lights all dead
Guys, need your help I turn the key and nothing happens no power no light no sound nothing all dead this is spunky. Battery is good has juice is fully charged.
Any suggestions?
Thank you
Old 04-16-2020, 07:40 PM
p911dad's Avatar
I'll hazard a guess, since no one else has. (I'm spending way to much time on this keyboard these days LOL) It could be a loose or corroded connection, and a likely culprit could be the battery. Pull the cables, clean the terminals and then tighten them securely. Or the alternator could be on the way out. Those are the easy ones. You'll need someone to test the alternator for that though. Good luck.
Old 04-17-2020, 12:41 PM
If the head lights do not come then not the key. Need to work back towards battery cables and battery. If head lights come on, then switch/column/dash. Need to work from battery out to find the short/failure.
97 993 RSCS Tribute (Poliezi)
96 993TT (Yel/Blk)
17 AMG GLE 43 (Blu/Blk) - 08 smart fortwo (Yel/Blk) -99 JD F 911 (Grn/Yel)
89 944 T (Blk/Wht) sold
Old 04-17-2020, 07:37 PM
You need a multi meter or a simple test light to test for 12V at the (+) battery post, then to the battery clamp, then to the cable conductor all to ground.
At the fuse/relay box in the front, pull DME relay and test at terminal #30 for 12V.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 04-18-2020, 05:41 AM
Is your keyless remote working?
Old 04-19-2020, 11:42 AM
