964 Batteries
Do any of you have experience with X2 batteries?
https://www.batteriesplus.com/productdetails/battery/car-and-truck/porsche/911/1994/h6-3.6l-650cca/sli48agmdp
Old 04-23-2020, 10:56 AM
You pay a premium to get anything from Batteries Plus. You can get an AGM with near the same specs for less. My 964 isn't a daily driver, and is hard on batteries, even with a maintainer.
The "correct" battery for 964 is group 91, which isn't common. Group 48 size battery will fit, but is about 15mm taller, which only slightly interferes with the front cover.
2010 987.2 midnight blue - SOLD
I make custom engine harness for your 914-6 conversion
'91 964 Targa guards red, cashmere - SOLD
several 914's and loads of parts
Old 04-24-2020, 01:23 PM
There's the minimalist approach as well...
Old 04-27-2020, 08:06 PM
Now in 993 land ...
aigel's Avatar
I have a similar setup. In service for 6 years now, no issues!
Rennline mount
Odyssey 925T
Battery Tender Jr. - low power consuming unit - CA approved
Pigtail fixed installation (like that these came with a fuse)
Thanks,
G
81 SC (sold)
Old 05-06-2020, 11:54 AM
Now in 993 land ...
aigel's Avatar
I had a follow up question, so here more detail on my setup:
PC925T-A
Part #: 0765-2020B0N0
Weight: 23.8 lbs
Rennline mount:
Part# EL36.35
Description: Rennline Battery Mount Kit Odyssey 925-1
The best thing is how reliable this is. Never felt it was undersized either in terms of cranking amps.
G
81 SC (sold)
Old 05-07-2020, 09:00 AM
