Door speaker size help
Hey,
Sorry for total newbie quesion regarding speaker fitting sizes.
I know there are plenty of discussions about the speakers themselves, but this is about hole sizes..
As you can see from the pictures the holes have been enlarged and I am not sure what size speaker should fit.
I do not want to enlarge the hole anymore.
So there are 5.25 or 6.5 speakers I have found locally that sort of look like a 964 grill to some point.
https://www.ground-zero-audio.com/en/produkt/gzif-52x/
or
https://www.ground-zero-audio.com/en/produkt/gzif-65x/
It looks like someone has also used a larger grill then the speaker, well they are from 2 different makes.
So just would like to know should I go for a 5.25 or 6.5 speaker in that hole.
All help appreciated
Alex
Old 03-12-2022, 02:34 AM
The stock size for the door is 5.25” but I’m not sure how it would work since the opening has been enlarged. Are you considering an adaptor to reduce the opening size and create a mounting point for the stock size?
Check posts 59 & 60, you’ll see that the opening has a black enclosure behind it that encloses the speaker and also provides the mounting point for the screws. https://forums.pelicanparts.com/porsche-964-993-technical-forum/1098094-picked-up-keeper-marine-blue-964-a-3.html
CURRENT:
2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black
1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue
2024 Macan White, Beige / 2010 Cayenne White, Black
PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey
Old 03-12-2022, 06:43 AM
Hey,
Well I am unsure if I put 5.25" back with the plastic cups at the back and not sure what they do and I don't have them anyway will 5.25 gills cover the holes, that's basically the key thing here and deciding factor which way I go.
If necessary as a cheap option I could buy those adaptor rings if I can find them.
BTW I do not have stock grills.
I have no worries going to 6.5" if they fit in the larger holes that have been made.
Thanks for your help.
Alex
Old 03-12-2022, 11:15 PM
964TargaC2's Avatar
"the plastic cups at the back and not sure what they do"
They are "umbrellas" for the speaker...keeps water from dripping directly on them
I went with 6.25 without cutting, I used a spacer because the magnet on speaker rear protruded too deep...also there was some one on here that made a mdf mounting plate
See these threads
https://forums.pelicanparts.com/porsche-911-technical-forum/778272-door-speaker-spacers.html
https://forums.pelicanparts.com/porsche-911-technical-forum/1111820-mounting-5-25-speakers-doors-not-door-card.html
I think that maybe I'm dreaming..
Old 03-13-2022, 09:59 PM
