budge96's Avatar
Very nice thanks been trying to sort this for a few months but having the car on opposite coast doesn’t help going back out in a couple weeks hope to get it all nearly sorted once and for all ,I take it the ABS wheel was pressed off the 964 inner washer and pressed on the 993 washer , cobalt had mentioned this but I guess I just had difficulty picturing it , thanks again , Bert
GT2
RS 3.2
RSCS 3.8
R 2.5 Twin Plug
Old 08-11-2025, 07:01 PM
Yes - you'll also need the 993 ABS sensors in the front. The prices (and lead times) really add up. I replaced all the parts...all new bolts for 993 and little plastic shells/clips.
Old 08-11-2025, 07:58 PM
Awesome car. Glad you were able to get it back. Was meant to be yours!
Old 09-09-2025, 08:53 AM
budge96's Avatar
Ok so I just managed to obtain the 993 ABS tone rings .. Cobalt ( Anthony) mentioned he pressed the 964 ABS ring onto the 993 center washer did you do this as well or simply ran them as they (993) are ?
Wouldn’t that cause a code with different number of ABS tooths ? About to switch this out let me know please appreciate your experience thanks Bert
GT2
RS 3.2
RSCS 3.8
R 2.5 Twin Plug
Old 09-09-2025, 09:40 AM
100% need to use the 964 teeth on the 993 center. Other option is to use C4 front outer CV - cutting off just behind the tone ring - essentially creating a threaded bolt and ABS ring all in one. The main benefit is really just being able to torque the hub nut without holding the bolt from the rear (tire is on the ground)..and this IS a help as I had to get help to hold the bolt head from the rear when assembling mine.
Really the best front hub you're going to get is 993 upright, hub and washer, with 964 abs ring.
Here, I changed the studs as well...also a good time to refresh the little clips, use 993 bolts and caged nut assemblies.
PS - timesert those caliper threads.
Old 09-09-2025, 12:18 PM
Old 12-02-2025, 07:44 AM
The stance is perfect! That looks like the Tail of the Dragon in that first pic.
CURRENT:
2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black
1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue
2024 Macan White, Beige / 2010 Cayenne White, Black
PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey
Old 12-04-2025, 07:37 PM
